are the grill mounts detachable for the n1 headlamps? or are they moulded to the housing? iv seen some n1 types that have the mounts and some doesnt have it..attachicon.gifimages.jpgattachicon.gifpicture008g.jpg
With mounts = R32 GTR N1 headlights, to secure front grill.
Without mounts = R32 GTS-T headlights.
This is not entirely correct.
No the standard GTS-t's did not have the clips for the grill, although they did have screw holes for an option to fit the brackets (which were metal) for a GTR style grill. You can get these through NISSAN. So any reflector style (N1 style) headlights that have the brackets which are held on by screws and are removable, are NOT genuine N1s.
The genuine N1s have the brackets which are plastic and are molded into the body of the headlight itself. These are NOT removable.
Sorry Damien but that is not accurate.
(OO)SKYLINE(OO) is right.
Genuine N1's do not come with plastic brackets molded into the headlight. Standard R32 projector type headlights do.
If you were to source N1 (Zenki) Headlights from Nissan they come with metal brackets that are bolted each N1 headlight.
GTS'ts have N1 type headlights without brackets and can sometimes fool people that they are genuine N1 headlights.
I have both sets (with N1 recently purchased) be more than happy to post up pics for comparison.
Edited by Ants
Hey Ant,
I spoke to Kudos (SAU trader) about 6 months ago about this same thing as i was after genuine Zenki N1s, and he supplies them direct from NISSAN Japan, and he assured me the brackets were molded plastic (like the GTR projectors) and are part of the body and not removable. This is what distinguishes the difference between the N1 and the GTS items.
I did a fair bit of research into this as i was searching for a set myself, and i found a lot of conflicting information and could not get a straight answer, so i spoke to a specialist who deals in new original Nissan parts.
Ill ask someone on here who i know purchased a set through them so i can get a straight answer and ill let you guys know.
i prefer my projectors ;)
i wonder why they never moulded the braket on?
Well I have both. So change it when I want :yes:
No idea why N1's were not molded on - maybe it was in case they got damaged in racing it was easier to fix up :closedeyes:
hmmmm, bolts=metal, they should be moulded for light weight :D
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
