So while i have everything out of the engine bay i have decided to repaint it. I'm thinking silver, should work well with the burgandy/maroon colour the car is. Also while there is nothing sitting in the engine bay i have decided to start chasing a little extra steering lock. This will be brought about by;
> modifying the x-member and moving the steering rack forward 20-25mm to minimise steering bind at full lock
> using R33 LCA's to increase front track and negative camber
> using A32 maxima tie rod's which are 325mm in length, longer than standard R32 items
> getting standard knuckle's modified by JDI fabrication
> keeping standard R32 tie rod ends
> using GKtech steering rack lock washers
Overall this should provide a fairly decent amount of steering lock without going to ridiculous lengths. A few people i have talked to have said that this setup provides them with more lock than they need to use, which is good news :)
Also, GATE!
10171105_10152410893423130_4480028552905
Needs moar engine to be attached to. It's currently at the fabricator getting baffles and trapdoors in the sump :)
Has already been machined for external VCT feed, internal VCT feed welded up, sent to the machine shop and machined flat and had a braided line made up. Still needs tensioner tapped, sump finished, drill and tap bosses for knock sensors, -10 AN fittings welded to the sump.
Will also get braided lines made up for the power steering which will be P clamped in position.
Then I will get it back and assemble the engine and drop it in the car, take it back to fabricator and get dump pipe, screamer pipe and 3" full stainless straight through exhaust made up. Should sound angry, but never heard an RB with full straight through staino before so slightly worried about volume haha.
So i have decided to redo the wiring loom and ditch anything that is not necessary. Downloaded the R34 service manual and jumped in trying to nut everything out. Was a bit confusing at first but with the circuit diagram and the ECU pin out it made life easier. I think i have figured what i am able to cut out of the loom and what i have to keep (everything highlighted is staying).
Also a before and after of what the loom should look like. Obviously there isn't over 100 wires standard as some are unused, but it still cuts it down quite dramatically :)
I was originally planning to keep the ECU in the standard position and run the loom up behind the dash and through the firewall on the drivers side using a Deutsch Autosport bulkhead connector. Part of the reason i wanted to do this was that it would make life easier if i ever had to take the engine out again, and partly because it is a cool idea and would give me some experience with wiring. Following wiring diagrams and making a Mil-spec loom seemed like a pretty cool idea to me as it is the sort of stuff that i would actually enjoy doing!
Unfortunately other priorities have taken over and i don't think i will have the extra cash lying around to be able to use the bulkhead connector. At around $120 a pop it is honestly money i am better off spending elsewhere on the build (don't worry, it has already been spent on other cool things haha)
I will still be leaving extra wires in the harness so as i can connect them up to oil pressure, oil temp, water temp and air inlet temp sensors to feed that information back into the ECU. Eventually i would like to run a IQ3 dash or something similar with all the info i will ever need on there, so deciding to do it this way to futureproof.
Also had some mates come round on the weekend (thanks Sean, Callum and Jordan!) and prep my engine bay for paint. It is the one thing that has always annoyed me about the car. It has been partly epainted in a similar red by the old owner but it really wasn't even close to the original colour. And in other spots the paint had started fading. I really regretted not doing it when i dropped the 25 in so this time i made sure it got done.
I got talked into going silver by my mates when i really wanted to go bronze in the engine bay, to match my wheels. They all thought that it came out great but i'm not sure i'm 100% convinced with it yet. Will see what it looks like when i drop the engine in.
  • 4 weeks later...
Looking good man, wish I had the time to spend on my car like you.
Took me 5 weeks to install a turbo lol
Haha fuark that. When i was originally putting the Neo in that's what it was like for me, only had access to it for maybe 5-6 hours a week. I had no idea what i was doing so i spent 4 of those hours standing there looking at it trying to figure out what i was doing hahaha. I am glad i have some sort of clue now ;)
Fark yeah nice work, loom looks very tidy, wiring scares me so I paid someone to do mine ha
Yeah it scared the shit out of me too man, but i just jumped in and had a crack! I just spent ages looking through the wiring diagrams and reading the service manual figuring out exactly what every component did, then deciding if it was need to run or not. It took me maybe 8 hours of finding what was what and if it was staying or going, and then another good few hours wrapping everything in the braided wrap. Now it's just a matter of fingers corssed and hope it all works!
Have been away for work all this month, back on the 27th and then off again to New Zealand early in July. Hopefully i can get the engine assembled between then, that way when i get back from NZ i can focus on getting it running :)
I think i have almost everything i need now except a fuel pressure regulator and i need another 7psi wastegate spring, oh and still need to get the ECU.
Big things happening soon hopefully! :)
Progress!
> Put spigot in, used ARP bolts for flywheel, put flywheel on.
> Removed flywheel and put gearbox cover plate on.
> Put flywheel back on.
> Gearbox on
> Attempted to put engine in
> Removed clutch master cylinder
> Put engine in
Thoughts on everything so far. I need a new clutch master cylinder as the R32 one is too long and fouls on the plenum. Will be going the tried and true method of getting an R33 item. Extended sump site perfectly between the cross member and swaybar, couldn't be happier with it fitment wise. I use Nismo engine mounts and only found out while putting the engine in that they sit the engine higher than standard nissan mounts. The bonnet will be very close to no shutting, i think i will have to cut out the ribbing on the inside of it to be able to shut it haha, it's something i am slightly worried about. Also the turbo looks a whole lot bigger sitting up high and not lurking down out of view anymore!
When i get my cooler piping done i will get my fabricator to make the rad support removable as it really is a pain. I don't plan on taking the engine out (obviously!) but it will be so much easier if i have to. Any one have any idea of the legalities of a removable rad support?
Next up is putting everything back into the engine bay and connecting everything back up, which i can't wait to get stuck into!
Eh, i have given up on trying to make dates as to when stuff will be completed. It always makes me sad when they come and go haha. Realistically sometime in October but if the stars align hopefully as early as september :)
Nice! I've always wanted to have an RB25/30 but I never had the time, knowledge or money to be able to do it.
I'm just going to push my neo until it breaks and then that will give me the excuse to do what you have done.
Awesome job on the loom also!
I never thought i would have the time, money or knowledge either! But then i found SAU and just started reading everything possible. Then when i killed my Neo i had plenty of time to read up. After all the reading i had the knowledge, and because so much time had passed i now had the money hahah :)
I just love knowing how things work and love having a crack at whatever presents itself. Every single thing on the car has been done by myself with no formal training at all, just a can do attitude and the internet haha. It's such a good feeling when you complete something that not long ago you would have never believed possible.
  • Like 1
  • 4 weeks later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
