  • 3 weeks later...
Nah I just want a standard one with the front chopped or a legit GTR one. Only running this one as this happened unfortunately.
Edit. Forums being gay can't upload pics. Bonnet made love with windscreen and roof.
I remember when your 6th piston didnt like the world and overheated.
quick question, are you still running the gktech clutch Fan?
Because ive heard nothing but problems with that fan on Neo engines, Stock is better.
stock fan with a decent radiator works tits, those GK Tech fans are hideous - pointless mod, I removed two of them off 2x S15s that were overheating on the track.
Yep still using GKtech fan. Temps are fine but haven't abused it on a really hot day yet. I need to find a R32 radiator shroud first then a stock clutch fan that actually works which will be difficult. Once I have all the parts I will do it then :)
Have Gktech fan on S2 RB25, stock shroud, temps are great, done many laps with no problems. Only complaint is fan hub is always locked when running, but don't know if that's because of the fan or not.
Bought a shroud, should be here mid week. Doing a drift day at wakefield next Monday so I'm super keen for that.
Bought some tyres to get out on rims, as did my friends. Lucky we have access to a tyre changer!
  • Like 1
  • 3 weeks later...
Cam seal has been leaking since the car has been running. Decided to fix it today. Pulled all the shit off and found scoring in the exhaust cam, and also found some black shit on it as well, looks like the seal may have been unlubricated and is slightly melted onto the cam. Sweet.
So undecided what to do at the moment. Will grease them up and has been suggested to put the seal back in but not in the same position as before. IE 1mm further in or out.
Also had planned to do a wakefield drift day 2 weekends ago, but the night before it the MAP sensor on my ECU dishonoured it's family and killed itself for some reason. So took it to Jez and he swapped it over for me (top bloke).
Fun times.
post-84937-1429443694734_thumb.jpgpost-84937-14294437116086_thumb.jpgpost-84937-14294437318415_thumb.jpgpost-84937-14294437609681_thumb.jpgpost-84937-14294438267172_thumb.jpg
I'd like to know how you get the timing right, is it just a matter of getting the right belt , install tensioner on block and just line the marks up or is there a more precise way to get it spot on?
Can you get adjustable wheels for both intake and exhaust side then? Just trying to visualise how the crank and two cams can be in the exact spot without having everything adjustable..
Can you use the tensioner for adjusting it too? hmm
Edited by AngryRB
Was just after a quick answer, i know what a tensioner is for, thanks for your wise answer, its an hour drive each way with an engine on the ute for me so id rather learn on here... from what ive read so far, the timing on an RB30DET can be tricky compared to a stock RB25, ill just line the marks up and let my tuner check and adjust it before its tuned then.. ;)
Edited by AngryRB
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
