The regs said 95db limit, but they didn't have anything to test it. There were a couple of cars running screamers and I'm sure they would have been at least 110db LOL. You'd fit in fine ;P
Let me know when the next decent event is on and ill try make it down ;)
For sure man :D
There is an Esses Descent planned on the 30th March but not 100% sure if it will go ahead.
Hillclimb on Mountain Straight on 31st August, Supersprint on Conrod on 2nd November and again the 29th November as well as a Hillclimb on Mountain Straight again on the 30th November.
For sure man :D
Oh nice! Well ill have too pick the one that suits my car best :P Can i just do conrod by itself? :laugh:
Yea man, the Supersprints are just Conrod so you could just do one of those days. But I will insist that you do a hill climb as well man, would love to hear your car hitting gate all the way up the mountain :D
If they let me that is :P Would be keen to give it a crack :yes: I was pretty jelly once i knew you were there!
Well, when people say that Jim Berry likes to talk, they don't lie :P . I was on the phone to him for about an hour and a half total today, but I learnt a lot (and a lot passed right through one ear and out the other too! haha). I have now ordered a custom clutch and new flywheel from Jim himself. It is almost the same as what Mat (34GeeTeeTee) is running, a 6 puk solid single plate, except with 5000 clamp pressure. It is a bit overkill for my car currently but I am hoping that I will never have to replace it :) . Jim said he would get a start on it and give me a call back in a couple of days, so hopefully I'll get it sometime next week maybe then I can figure out exactly when I will be able to get help fitting it :P
Edited by timmy_89
Juts got a call from Jim to say he is sending the clutch/flywheel ^_^
Wow, he musnt of had too many phone calls today :ph34r:
(If he reads this i hope he laughs lol)...
Yeeep. Haha. Oh well, now I have some spare seals I guess :P
I know we had trouble getting the rear main seal right on mine, check it over and make sure it is 100% before fitting :yes:
He mentioned having trouble with the rear main, I'll line it before removing the old one and make sure it all looks right :)
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
