cant answer your question Shaun as I have no clue.
My squats have tacken a massive backward step. I just cant seem to improve on them.
I have good depth but weight is 60kg and not even by 10 reps, its a joke, really need to figure a way past this hump.
Eat more? haha
Is that 10 reps per set or just total?
  • 4 weeks later...
So I have this issue when squatting that is getting progressively worse. My right knee continually bends in, this is now causing a hamstring strain when I leg press. It was so bad today I gave up on my workout. Any suggestions besides band work? I will try doing squats with a band tomorrow. There's a suggestion it could be related to weak abductors? What are some exercises I can be doing? There's no abductor machine at my gym. Thanks.
We get this a lot.
Strip the weight back to an empty bar and do the movement correctly, only adding 2.5kg per session
Looking for another exercise to improve squat is not needed.
We dont have an abductor machine at PTC, I post all our vids up, no ones knees are folding in currently, but if you look back, way back, you will find some
just started implementing rear loaded squats into my routine, main reason I haven't been bothered thus far is my gym only has 2 barbell stations & they're almost always occupied (plenty of smith machines but I don't want to use those, always feel awkward)
My thighs are kinda naturally large anyway so this is mainly for the benefits of compound exercise rather than aesthetics
concentrating on getting my technique down pat atm so currently only on 40kg + bar 5 sets/10 reps (can definitely handle more but don't want to over-do it yet)
Once I feel more confident I'll slowly add weight per set
hardest thing I find is ensuring I push up from my heel but getting used to it now
Other than that tiger balm on my thighs is heaven
I personally find with squats, sets of 6-8 reps is sufficient. Any more and you need to increase the weight but that totally depends on your goals (who the fk doesn't want massive jacked looking legs haha) . Keep on top of them and make sure they are included in every weeks workout! I stopped doing them for 4-5 weeks as I got real sick after a holiday... Went from doing consistent sets starting @ 100kg and increasing up to 160kg. I do at least 4 sets too. Did them on Saturday... Struggled with 4-5 sets @ 100kg! Mind you I went from 94kgs to 85kgs in 4 weeks! Can't wait to get back to a respectable weight.
However, in saying that, I cringe when I see people doing sets that are way too heavy for their frame and are doing half arsed reps. Build a solid starting weight and go up in small amounts getting that ace to the floor each rep :)
Another tip for perfecting technique is to grab two small plates (1.25kg etc) and place them under your heels. Will help you get comfortable. Only needed to do this for a few weeks and it made my lifts feel more natural and comfortable.
^ I think I've gotten the handle on squats now :) I'll try the plates under the heels thanks for the tip
new PB:
1 X 40 10 reps
1 X 60 10 reps
2 X 80 8 reps
I'm happy with my progress considering its only 3 weeks in.
My goal will be to get up to 100 kg set & maintain from there, I'm happy with the size of my legs as they are & it's in proportion with my frame
Haha that video is gold. Smith can be used for some things, but if you squat with a barbell and then try a smith it feels really unnatural.
I've done the 'australian pull ups' (inverted row), he refers to in that video, on a smith. It was part of my back and shoulder rehab. So it can be useful sometimes.
I'd say to scale back on the weight a bit too to begin with if you go from using smith machine to barbell
Tried smith machine once & it felt really awkward.
This is the vid that inspired me to start using squats, not sure if it's been posted before I'm not going to go back through this whole damn thread
