So I've been to plazmaman. Apparently I have to shift the fuse box more to the guard.
So unbolt it, push it more to the left, redrill the hole then bolt it back in.
No where on their website does it say that shit needs to be moved....
Also the above piping, one is for the bov and the other is for the idle speed/control
  • Like 1
Picked up my headlights today from being cleaned and treated.
If you have a look at some of the front end picks of my car you would of seen how bad these were especially the drivers side.
I'm very happy with how these turned out
  • Like 2
Ah yeah i forgot to mention that! Mine is just a tech screw and cable tie lol
Lights look good on the car
Ran in to a small problem though, the bar doesnt fit with the new intercooler piping. Time for a bit of shaving
Just make sure you take a small bit at a time and do a good job of it... So many people hack them and just fk it all up!
Yeah that's the plan. We were discussing ways to do it Thursday night, keeping an even and clean look on both sides. I'll see how it turned out when I check on the car tonight after work
Hopefully once this is on and finish up the lines on the cold side, the rest of the gear should just fall in to place.
  • 1 month later...
Question for anyone whos following my build.
Plugged in the new haltech platinum pro, turn on the reds and the aircon fan switches on. Turn the car off, take the key out and the fan stays on as well as the reds. Fuel pump switches off. Turbo timer is connected but not turned on.
Anyone else come across this before?
Thanks dude. I'm happy with how the bay has turned out so far, still very far from my end goal.
As for the vct, the module was playing up since my last tune and it was holding the car back in 3rd gear so it needed to be replaced anyways so my mechanic decided to replace it with cam gears. I trust his judgement so we'll see how it goes when it gets tuned.
Speaking of tune, it's getting dropped off in the next few days :D
Can't wait until I get to drive it again
  • Like 1
  • 3 weeks later...
O.......k a bit of an update.
The car went to the tuners last monday, the wednesday before that he came out to my mechanics house and put a base tune in.
It was running very rich and rough, as you would expect.
While at the tuner, it was having a problem with idling. Sometimes it would idle fine, other times it would drop below 900rpm then switch off.
Eventually that got sorted.
Last wednesday my mate was on the phone with the tuner and I received the news that the car wouldn't be ready for mondays track day.
I was gutted that she wasn't going to be ready but I couldn't do much about it.
Last night while hanging out at my mates he gives me the news that the car is having further problems.
It's making 12psi boost on idle, sounds like it has a 2 step set up and won't rev past 3k rpm.
Tyler (my tuner) has been on the phone with Haltech directly and Adam from JEM.
Both Haltech and Adam have logged in to my car to diagnose the problem but neither of them can work it out.
Adam even suggested to tow the car over to him to have a look personally.
Haltech have suggested to swap out the ECU, which is being organised.
I can't thank Tyler (PVS), Haltech and Adam (JEM) enough at the moment. The effort and focus they are putting in to get my car up and running is crazy. This is the reason these guys have such a good name.
  • Like 1
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
