Bugger, happened to a mate of mine when his aftermarket bov fell apart and it got sucked into the turbo
Best of luck getting it back up and running
So initial word back from GCG is that the core needs to be replaced in the HKS, housing seems to be ok
We'll get a phone call sometime this week to go pick it up
In the mean time, we went a bit crazy on a recent order with HiOctane for the 34......
So we have got:
Haltech ECU
Tomei Type-B Pon Cams
Tomei Cam Gears
Walbro in-tank fuel pump
850cc injectors and FPR
Upgrades gears for the oil pump
All this will go in after the track day in September, I want to get used to the new clutch first before putting more power in the car
We'll also be putting in a Gates timing belt and a new water pump while we are in there.
Also planing to get a Plazmaman plenum, throttle body and Billet fuel rail, paint the rocker covers and clean up the bay a bit
BRB while I start on my Mi Goreng diet lol
  • Like 3
I'm not too fussed on the wait for the extra power but my mates and mechanic have been pushing me to do the work now and not wait until after track day.
I could do it all now and it might be ready by track day (all depends on my tuner) but I will probably miss the 32 GTR 25th anniversary day cruise/lunch next month which I really want to take the 34 to
Having no boost for a month is a killer lol, it's an addiction. The longest I've gone without the car previously has been 2 weeks so this is a real test for me, it's like giving up smoking lol
I am interested in seeing how much power I will get out of her once everything is in and the HKS finally pushed its limits (only running at 50% at the moment)
Looks like a fun combination haha. My car should be ready in September too, maybe we should organise a cruise somewhere...
Nice, what are you getting done?
I'll be up for a cruise up until track day late September, need to rack up the k's on the new clutch, come October she'll most likely be off the road again for the work.
Same as yours but instead of cams I'm chucking on an SS2 turbo. Should be pretty quick once tuned. Hoping for 300 at the wheels
So we have got:
Haltech ECU
Tomei Cam Gears
You only need the one cam gear man... And also why the upgrade for the oil pump? Mine has held up so far with the abuse...
Might look into head studs and cam springs if you want to run bigger boost, these can be done on the car without lifting the head :yes:
Organise your entry for the track day in September hahaha
I might do. It'll be pretty rubbish as it's on standard shocks though haha. Also I have no licence or helmet or gear or fire extinguisher. I might aim for the next one hahaha
I have spare helmet and extinguisher you can borrow
Licence is easy to get $50
This is about as tempting as a kebab after a big night on the piss. I'll see how the build and tune goes with Paul. Might just unplug the boost controller and run it as rich as a Saudi prince if it's too quick for the suspension
If I'm going to upgrade 1 might as well do both.
I'd rather play it safe with the oil pump, minimize the chance of failure in the future
Might be an idea. What's the limit on boost with stock studs and springs?
Stock studs held up OK when i was running 24psi but eventually i would have done a headgasket... I would say 20psi on stock springs and studs to be safe as long as you have a good tuner... Others might have different opinions?
Most engines start having issues once they have been messed with (in regards to bearings and bottom ends and stuff) best leave it the way it came from Nissan and thrash... I thought mine may have proven that to ya by now :P
  • Like 1
Sounds good seeing as my MAP sensor will only let me run 21psi haha. I hope I land in a pit of money soon so I can come on the track day
if you use the intake cam gear you are going to lose your VCT as its a single unit and cannot be mated to the adjustable cam because well thats sorta what VCT is!.
go take it back and get them $$ back!
if not you could always sell it to someone else and they can flip it around and use as an exh gear.
 Share
    • The stock one will outperform any aftermarket standard position exhaust manifold. If you don't believe me, do a back to back test (same turbo, same boost, same timing) and you'll be super surprised.
    • Any recommendations on a decent replacement manifold that doesnt break the bank or require additional mods for the stock turbo setup? I figure if I'm going to pull the manifold off anyway to fix the studs might as well replace it.
    • So I checked the turbo out today. Very minimum play at all just enough for the oil to take up when it's running. I did find an exhaust leak at the manifold. 1 stud all the way in the front is missing and the one all the way in the back is broken off. Front has visible signs of an exhaust leak. I'll fix that soon but that's not my problem still.  I also found that the nipple coming off the turbo had the hose capped off and a hose ran from the j-pipe by the bov going to the wastegate. I removed that hose and capped that nipple and put the turbo nipple hose back on the wastegate.  There was a ton of oil residue all through the charge side of the intercooler piping going to the throttle bodg. I'm thinking that's from the pcv. Doesn't seem to be coming from the turbo that was all clean on the pipes side.  Haven't had a chance to check fuel pressure yet, haven't had time been having to pull a lot of doubles at work. I did pick up some carb cleaner to clean the iacv but wanted to make sure I had a fresh gasket in case the old one rips when I pull it off.  I'm waiting on a MAF that was supposed to be here today but delayed to Monday. Have a double Monday and Friday and work all of next weekend so going to try to find some time in the middle of the week to try that out. Did about a 10m trip around the block today and towards the end the issues were coming back. Fingers crossed on this MAF but if not just going to throw a fuel pressure gauge in and see where I'm at.  Did notice today that I can definitely hear the injectors pulsing. Very audible clicking coming from them. Assuming that's normal? Should also mean CAS is functioning somewhat properly. After it warmed up when I started it the intermittent misfires came in again. Did start doing that before it was fully warmed up.
    • This morning I carefully reinstalled the manifold and started looking at a couple of things I need to do.  Heat wrap arrived sometime today so I popped into the shed with the missus dishwashing gloves and started wrapping the first half of the dump and the screamer/plumb back.  Once I do the second half I'll be able to final fit the turbo and exhaust up.  Also pulled the harness out today and started terminating it at the ECU end. A connector is done, just need to run the remaining wires that arent in the harness - 12v, gnd and couple I/O
    • A31 is pretty much the same thing without HiAIDS I mean CAS, no improvement lol. Not to late to send it.
