Sweet, I have transferred the money to you today. Looks like the list in the first post is full so Im on the reserve list?
i think there are a couple who can't make it so I'll swap you in for one of them
DRD-OOF send me a pm mate and we will arrange a swap for your spot
great for first timers
probably the best day to go on if you are a firts timer
you can go out and do passenger laps to learn bad habbits from the faster people
Best bad habits are learnt from Fatz and Neil...
Just updated Harry's Lap Timer on my iPhone and marulan is now on the track list. Nice!
What is this so called lap timer Dave???
By that logic I'm racing right now.
Its the only racing you'll be doing now that you're skyline-less.
+1 For Harrys Lap Timer. Best time was 46.13 last Fatz day, but i now have R888s instead of RSRs, a tensioned strut brace and an extra degree of neg camber on the front, so should be faster.
SHOULD be faster mr stabby hehehehe
Matt do a search for Harry's lap timer at the iTunes App Store. Free version is all ya need.
Oh and yes I believe you can get it for the android as well
Thanks mate, will do! Any testing in comparison to actual timing to check accuracy? Not that it matters for me as it probably doesnt record hours :laugh:
It's not too bad, sometimes drops out randomly but all in all not bad.
At wakie I was getting within 1/4-1/2 a second of official timers (Dorians etc) so for free it pretty good.
At least gives you an idea on wether you are improving
Sounds damn good! I guess as long as you have decent 3G connection?
Yeah pretty much, you can use a Tom Tom iPhone adapter for a better GPS lock if you wanna get serious but I would just just buy a proper timer if you were gonna do that.
Edit: there's a lot trees at marulan which dosent help with the GPS
Looks like harrys lap timer is in development for android, not released yet. I have grabbed racechrono and chronogps from the android store, hopefully they go alright tomorrow
Nah it doesnt use 3G at all for timing, you just need a good GPS signal, and the one in the phone isnt great. Probably would be best to fix the phone under the windscreen somehow. It also uses a lot of power, so take a charger. I use the tomtom cradle, since i use the phone for satnav as well, and it works really well with that since its got a built in GPS and supplies power from the cig lighter socket.
BlackT - re: racechrono - i used to have that on a nokia phone years ago, and its worked well with an external bluetooth GPS. Let me know if you need to borrow the GPS, its a 5khz unit that was recommended by the racechrono guys back then.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
