Alright, I've figured it out. 3 gates -_-
I'm assuming 1 per side of the stock manifold and another gate off the turbo housing as well? haha
imagine the noise :wub:
that's horrible for flow, why not just weld a gate flange off the rear housing?
I can't figure out who to goto to get a wastegate welded on... I'd personally prefer it welded on the manifold.
Don't bother sending a manifold to me, I can't die grind the opening to the gate from the inside, and if I can't do a job properly, I won't do it at all. These 90 degree entry gate pipes welded in a hole... you are better off staying internal gate imo.
The housing on the other hand has great access. I can clean up the gate entry in no time.
Scotty do the GT Ni Resist housings weld ok ?
Also I was looking at Turbosmart 40 and 45mm external gates just to get an idea of their dimensions . What size external gates are being used on say typical RB25 GT30 setups in the 3-400 wheel wasp area .
I wish I could find the pic of a Turbosmart gate on the housing in a Skyline bay because it didn't stand out that much . I suppose real stealth would be having the gate closer to where the exhaust returns to the front pipe .
A .
It is quite hard to hide the gate, as there is no room to weld the gate underneath the turbo. You could mount it down where the dump is, but the pipe leading to the gate will be a little longer than I would like. (Plus it would need to be welded onsite)
The GT cast iron housings are very hard to cut and diegrind, but they weld fine. Stao's housings cut like butter and take half the time.
I would use 45mm for the gate, or perhaps larger. The boost control would be fine with a 40mm, but power would be more restricted. The 45mm gates are the same size Vbands as the steampipe I use so they flow nicely.
  • 4 weeks later...
from my testings, running the same turbo externally gated on turbine housing with stock manifold made less power then the same turbo on aftermarket manifold internally gated, and even lesser against aftermarket manifold externally gated.
Turbine housing has been untouched all times, the manifold is restrictive. So scientific solution would be attaching the external gate to the manifold. But factory manifold is twin log, do them properly requires extra work and skills, (I'm in process of building one at moment) while external gate from turbine housing makes the job easier.
Hay did end up building your manifold ?
Interested in what you came up with !
  • 4 months later...
You can't do much with it, or you will force the pulses into the other side of the log. The divider needs to stay. I would even extend it a little, to just before the gate.
I found better results by making the flow path smoother. You can't really do this running the gate off the manifold as you can't die grind it after welding.
Ok. Maybe I am spazzing out, but how late on the housing could the gate be welded on?
Now I know common sense says put it where everyone puts it, close to the inlet, but I don't want to!
I would like for ultimate stealth Ness to weld the gate pretty much at the end of the scroll, so it is directly under the turbo and hidden. (Using the stock manifold)
Is that too silly? The way I see it if the little internal gate flange can work pretty well, a less than ideal external gate would still work sort of good? I don't need to be able to run low boost
Whatcha reckon?
I reckon the further around you put it the more restrictive the whole thing will become.
Remember 2 things. There is a total amount of exhaust gas that has to flow and there are 2 holes that it needs to flow out of. If the wastegate opening is early in the flow path (ie, on the manifold, or near the inlet end of the turbine housing) then that gas that goes out the wastegate does not have to flow around the steadily decreasing area of the scroll. If you locate the wastegate a fair way around the scroll, then all the turbine gas plus all the wastegate gas have to flow that far, instead of just the turbine gas. The back pressure will climb for every extra little bit further around you put the gate.
I wouldn't do it.
I think the issue with that (I asked Mr Scotty for the same thing) was that there's actually no room to put one there?
I could very well be dreaming, but I'm sure from underneath I can easily see the whole turbine housing. Maybe there's more room in a rwd stagea. Or maybe I am retarded.
The way I see it there isn't an ideal point to mount it on the manifold and the throat of the turbine housing is the largest area downstream of the six passages merging . Even then the mount angle sometimes isn't ideal but if you want part of the gas stream to change direction its easier to do that where the passage is larger .
For the work involved go the turbine housing or use an aftermarket manifold if you want the gate/s on it .
A .
Theres heaps of room underneath and it isn't much harder than having it higher up, mine was on a low mount 6 boost and still was enough room.
There was no boost control issue, it did seem a bit laggy though, but not sure if it was just the twin scroll ATP housing or not.
Edited by AngryRB
Do you have a pic? The 6boost manifold positions the turbo different to stock doesn't it? Sort of like an hks cast one does?
Ummm. You realise that the external gate has exhaust gasses flowing through it and is welded to either the exhaust manifold or the rear turbo housing? They withstand an incredible amount of heat. You can even get water cooled gates.
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo :-D
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
