Looking at some new front discs for a non-Brembo R32 GT-R as the oldies are starting to squeal constantly and RDA seem to be the cheapest decent discs around for a decent price. What i'd like to know is if there is going to be a big enough difference in performance between their plain discs and their basic slotted drilled discs to justify spending around twice the price? It's only due to still having the original nissan calipers that we're looking for a cheap 'band-aid' solution to last a couple of months.
https://www.sau.com.au/forums/topic/425219-worth-the-price-hike/
seems you need to decide if you want cheap band-aid fix or something decent...
have been told the RDA dimple ones are a good way to go.
Yeah, not got the funds for better discs, but bigger brakes are already high on the list of needs so it's only going to be temporary hopefully. I suppose everyone here goes GSLRallysport for their RDA+QFM setups? Any one maybe in Sydney or Newcastle or in between?
Edited by K4L4M1TY
Plain discs (Not slotted, drilled or dimpled) work fine on road cars. So just get some of them and save your money.
Just rang GSL Rallysport and Brakes direct, both same prices and said plain discs are actually more than the slotted ones. Shipping will be a bit more from GSL probably but i'd rather go with an SAU advertised dealer than anyone else and especially over the guy on Ebay with some hilarious feedback. I think i'll ring GSL back and see what they can do for postage on them, cheers for the advice so far.
Slotted rotors work, I reckon the pad bite is unreal.
However no, I don't appreciate the price difference.
I buy standard rotors for 70-90 bucks a pair and send them to a CNC machinist friend who slots all my new rotors for a quick cash job. I generally end up at least 50 bucks and sometimes well over 100 bucks ahead of buying them from RDA/DBA etc
All that needs to happen is to set out an inner radius of pad area, an outer, and to make some arcs any slight radius rouhgly 6 times over the rotor. Then flip over... An easy task for any CNC machinist who knows what they're doing with a bullnose bit.
Alternatively, I reckon the Sumitomo calipers are more than enough for a Skyline... Just a decent set of pads and standard rotors should do.
if you honestly want a cheap band-aid fix for only a few months, try ebay rotors.... mine havent fallen apart yet :ph34r:
Was going to until I read some guy actually got a used machined disc in his set which put me off instantly, like how bad do you have to be. Rang GSL Rallysport back and ordered the RDA front discs and a set of the QFM HPX pads. Told him I found him through SAU too which he seem pleased to hear. :3some:
Greg at GSL said RDA had updated their range and they were some dark anodised style dimpled discs so i'm keen to see how they look aswell. All I can say is thanks for the help guys and a big thanks to Greg at GSL for being very helpful over the phone and organising it all promptly, cheers mate. :action-smiley-069:
Why have you got big brake upgrade high on your list?
Do you take your car on the track a lot?
The stock brakes are highly effective for quite a while if you upgrade the pads and rotors before you need to go spendkng thousands on bigger brakes
With a few simple mods the car can be pushed easily to 350kw, with internals its 400, but yes the car will see plenty of track time once it is reliable enough not to break parts. The pads arrived on Friday, discs today. I really hope they get rid of the soft, spongey, very un-nerving feeling the car has had since purchase..
Look at adjusting the brake peddle up.
Similar problem on my 32GTR (ABS).
I have replaced everything with new to get rid of this - Discs, pads, callipers, braided lines, BMC upgrade, Booster. Bled 5 times with new Motul 600bf (by 3 different JDM Import shops).
About to replace new Ultimate pads with new Project MU HC+ pads (not cheap) any of this.
Note: ABS DOES NEED BLEEDING.
I'm fairly certain now that I need to adjust peddle to where I feel comfortable/confident.
I should have done this first :/ (plus it should have been suggested by said "experts").
Edited by Sinista32
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
