Yep, V1's, I didn't get a choice in spring rates at the time, so I can't remember the rates, I got the first ever set shipped I think. Just go with the standard setup and they should be very comfortable.
The arm is 28781AQ010 and I got it direct from Nissan for $55 and the blade assembly is AY003H25AR unsure how much from Nissan. You will also need a refill I assume.
Copied and pasted from other thread.
http://nissan.epcdata.ru/stagea/pnm35/6845-vq35de/body/287/?frame_no=PNM35700538
  • 4 weeks later...
http://www.ebay.com.au/itm/181138430477?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
This is the cheapest pollen filter I could find to fit a M35 at about $11 delivered. I fitted the same one a few weeks ago & the quality seemed at least as good as the Ryco one I used before. The postage from the UK only took a week too.
Radiator hoses
Nissan Part No.
21501AL5000 upper hose
21503CD000 lower hose
Gates Part No.
22967 upper hose
22968 lower hose
Oh and Burson Part number for Koyo V35 radiator
NIS081pacak I think.
I was at work looking for the part numbers in the Ecatalog and couldn't find a listing for the 350z's so after I trolled through EPCDATA and then google searched the nissan part numbers those came up in ebay. Can be had quite cheap.
Edited by M35woah
My edit button has gone :(.
But more research on the hoses as Gates had none in stock and would take 12 weeks to get it, faqdat.
So I found out Mackay has got em!
Upper: CH4966
Lower: CH4962
or CH4960
The two lower hoses I believe will fit but CH4960 has a slight extra bend.
Uh oh. Thinking about buying another M35.
Was seriously thinking about a R36 Passat but after closer inspection they are bigger and heavier than both NM35 (200kg heavier) and PNM35 (~80kg heavier).. assuming my specification sources are accurate.
So tell me about these PNM35's lads - what is stock power like compared to a stock NM35? How is fuel economy? I know a lot of you don't care but lets be honest, petrol prices are only going in one direction.
Any things that are highly desirable on them like the NM35? Trans cooler, shift kit, upgraded radiator? Any other common problems?
If you want boostz and powerz go NM35 which I think you know :P
If you want to keep yo keys in your pocket when start and unlock the car and have nicer interior then PNM35 is for win.
Petrol is probably similar, as for shift kit and trans cooler they can be optional, radiator not needed if staying stock, don't have to budget for new tubz or AFM.
Stock power is fine for day to day, but coming from a modded NM35 you'll probably want more.
Get a trans cooler and Scott's coolant mod. You can stick with the OEM radiator without concern unless you are going to boost it of course.
Also, should note that the PNM35's don't have that seemingly problematic pump for the ATTESSA.
Shift kit I hear is good although they do shift noticeably better than the NM in stock form.
Petrol is very slightly better although they are flash tuned if you feel the need (or want).
No real "common problems". Pretty solid car all round and having owned both, can certainly say that the PM is much nicer than the NM.
"If you want to keep yo keys in your pocket when start and unlock the car and have nicer interior then PNM35 is for win."
I cannot stress enough how awesome it is to not have to take the keys out of your pocket... at all.
External lock/unlock buttons on the front doors and hatch. Keyless ignition (although you can still put the key in if you need to).
Also, PM35's look better :P
Yep, I followed yours with interest but I guess if I was going to go with a PNM35 it would be because it's NA. Adding a turbo would ruin the simplicity that I like about them.
What is a reasonably sort of power figure to get out of one without ridiculous mods? Say intake and exhaust with a remap?
Or do they need cams, etc?
Almost nothing. It's just not worth modding one besides some really basic stuff. It's too expensive for the gains compared to a turbo car. Anything from a 350z motors will fit them, so you can go nuts, but realistically, most people are happy to have a bit more noise and breathing. I don't want to give a power figure, cause whatever dyno you go on will be different.
If I was to "finish" mine, it would have high flow cats and a uprev tune. No cams or headers. Mine currently runs 94mph, I think it was, down the 1/4. Compare that to the nm35 numbers in relation to power.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
