Can someone please confirm nm35 suspension (shocks) front and rear part numbers. I think in this it states 350z premium is compatable.
Fronts won't work for AWD because they have a different bottom as they don't have to avoid a driveshaft. If your car is RWD they may fit.
Rears should fit, but front deff wont.
The G35x is closest to our car for AWD purposes.
Edited by M35woah
I don't even think the rears will work; don't they run a true coilover, rather than separate coil/shock?
The reason M35's run them separately is to allow a flat cargo floor with no intrusive strut towers.
Sedans & coupes have no need to do this.
Yep, scratch my last comment; but the shocks on 350Z & V series look to be quite a bit longer.
Agreed Scotty, for the price of a set of KYB shocks; you're 2/3rds of the way to a set of BC's.
And they'll sell you a replacement damper for $100ish is you ever need one.
In cabin pollen/AC filter.
Nissan part number 272774M400
Ryco PN:RCA113P
http://tygarbyte.blogspot.com.au/2012/10/m35-stagea-air-con-filter_6431.html
Has anyone changed the A/C cabin filter ?
Also what filtet/part number did you use ?
Bugger... today my M35 developed a major slip in drive. Ok in reverse. Anyone else have this problem.?
Who has an auto for sale in syd ?? Might be a quick fix, till i can see whats wrong with this one. It's the family daily drive..
Edited by FIA510
^ Dude - wrong thread for that question. Start a new thread.
I used Ryco PN:RCA113P to replace my cabin filter. Old one (a bosch) was rank too.
There's also a Ryco with a C at the end of the p/n which designates it as an activated carbon/charcoal filter, this is the correct replacement for the factory one.
I'm wanting to bag my 2002 M35 and was wondering if a 370z airbag kit would fit? Reason being it's impossible to find a specific kit for a Stagea and I don't wanna go down the custom route because it's gonna be EXPENSIVE! I considered coilovers but it's gonna be stupidly impossible to drive on normal roads and over speed bumps with the height I want. Any help would be appreciated, cheers.
Doubt it.
There are bag kits available for the M35 Stagea in Japan though.
Best bet would be to look on Import Monster or contact Jesse Streeter
  • Like 1
This is your problem, so why be stupid at all?
The crossmember is the lowest point, I wouldn't want to hit something solid with it...
Doubt it.
Nothing local, but yeah IM or Streeter can sort this one out for you http://page4.auctions.yahoo.co.jp/jp/auction/d148045989
Depends on your definition of 'expensive' too though.
I contacted import monster before posting this and they advised me of a couple of airbag companies, sadly none of which had an M35 kit. I only want bags so I can drop the car while parked, 19x11's and 19x10's would look good with coil-overs but when I want to drive away I wanna have a comfortable ride without getting stopped by the police. The only kit I've seen for an M35 was $5,700 Aus and that's abit excessive just for suspension in my opinion.
Wish I could read Japanese, it would help with a lot of things.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
