Can someone please confirm nm35 suspension (shocks) front and rear part numbers. I think in this it states 350z premium is compatable.
Fronts won't work for AWD because they have a different bottom as they don't have to avoid a driveshaft. If your car is RWD they may fit.
Rears should fit, but front deff wont.
The G35x is closest to our car for AWD purposes.
Edited by M35woah
I don't even think the rears will work; don't they run a true coilover, rather than separate coil/shock?
The reason M35's run them separately is to allow a flat cargo floor with no intrusive strut towers.
Sedans & coupes have no need to do this.
Yep, scratch my last comment; but the shocks on 350Z & V series look to be quite a bit longer.
Agreed Scotty, for the price of a set of KYB shocks; you're 2/3rds of the way to a set of BC's.
And they'll sell you a replacement damper for $100ish is you ever need one.
In cabin pollen/AC filter.
Nissan part number 272774M400
Ryco PN:RCA113P
http://tygarbyte.blogspot.com.au/2012/10/m35-stagea-air-con-filter_6431.html
Has anyone changed the A/C cabin filter ?
Also what filtet/part number did you use ?
Bugger... today my M35 developed a major slip in drive. Ok in reverse. Anyone else have this problem.?
Who has an auto for sale in syd ?? Might be a quick fix, till i can see whats wrong with this one. It's the family daily drive..
Edited by FIA510
^ Dude - wrong thread for that question. Start a new thread.
I used Ryco PN:RCA113P to replace my cabin filter. Old one (a bosch) was rank too.
There's also a Ryco with a C at the end of the p/n which designates it as an activated carbon/charcoal filter, this is the correct replacement for the factory one.
I'm wanting to bag my 2002 M35 and was wondering if a 370z airbag kit would fit? Reason being it's impossible to find a specific kit for a Stagea and I don't wanna go down the custom route because it's gonna be EXPENSIVE! I considered coilovers but it's gonna be stupidly impossible to drive on normal roads and over speed bumps with the height I want. Any help would be appreciated, cheers.
Doubt it.
There are bag kits available for the M35 Stagea in Japan though.
Best bet would be to look on Import Monster or contact Jesse Streeter
  • Like 1
This is your problem, so why be stupid at all?
The crossmember is the lowest point, I wouldn't want to hit something solid with it...
Doubt it.
Nothing local, but yeah IM or Streeter can sort this one out for you http://page4.auctions.yahoo.co.jp/jp/auction/d148045989
Depends on your definition of 'expensive' too though.
I contacted import monster before posting this and they advised me of a couple of airbag companies, sadly none of which had an M35 kit. I only want bags so I can drop the car while parked, 19x11's and 19x10's would look good with coil-overs but when I want to drive away I wanna have a comfortable ride without getting stopped by the police. The only kit I've seen for an M35 was $5,700 Aus and that's abit excessive just for suspension in my opinion.
Wish I could read Japanese, it would help with a lot of things.
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
