Can someone please confirm nm35 suspension (shocks) front and rear part numbers. I think in this it states 350z premium is compatable.
Fronts won't work for AWD because they have a different bottom as they don't have to avoid a driveshaft. If your car is RWD they may fit.
Rears should fit, but front deff wont.
The G35x is closest to our car for AWD purposes.
Edited by M35woah
I don't even think the rears will work; don't they run a true coilover, rather than separate coil/shock?
The reason M35's run them separately is to allow a flat cargo floor with no intrusive strut towers.
Sedans & coupes have no need to do this.
Yep, scratch my last comment; but the shocks on 350Z & V series look to be quite a bit longer.
Agreed Scotty, for the price of a set of KYB shocks; you're 2/3rds of the way to a set of BC's.
And they'll sell you a replacement damper for $100ish is you ever need one.
In cabin pollen/AC filter.
Nissan part number 272774M400
Ryco PN:RCA113P
http://tygarbyte.blogspot.com.au/2012/10/m35-stagea-air-con-filter_6431.html
Has anyone changed the A/C cabin filter ?
Also what filtet/part number did you use ?
Bugger... today my M35 developed a major slip in drive. Ok in reverse. Anyone else have this problem.?
Who has an auto for sale in syd ?? Might be a quick fix, till i can see whats wrong with this one. It's the family daily drive..
Edited by FIA510
^ Dude - wrong thread for that question. Start a new thread.
I used Ryco PN:RCA113P to replace my cabin filter. Old one (a bosch) was rank too.
There's also a Ryco with a C at the end of the p/n which designates it as an activated carbon/charcoal filter, this is the correct replacement for the factory one.
I'm wanting to bag my 2002 M35 and was wondering if a 370z airbag kit would fit? Reason being it's impossible to find a specific kit for a Stagea and I don't wanna go down the custom route because it's gonna be EXPENSIVE! I considered coilovers but it's gonna be stupidly impossible to drive on normal roads and over speed bumps with the height I want. Any help would be appreciated, cheers.
Doubt it.
There are bag kits available for the M35 Stagea in Japan though.
Best bet would be to look on Import Monster or contact Jesse Streeter
  • Like 1
This is your problem, so why be stupid at all?
The crossmember is the lowest point, I wouldn't want to hit something solid with it...
Doubt it.
Nothing local, but yeah IM or Streeter can sort this one out for you http://page4.auctions.yahoo.co.jp/jp/auction/d148045989
Depends on your definition of 'expensive' too though.
I contacted import monster before posting this and they advised me of a couple of airbag companies, sadly none of which had an M35 kit. I only want bags so I can drop the car while parked, 19x11's and 19x10's would look good with coil-overs but when I want to drive away I wanna have a comfortable ride without getting stopped by the police. The only kit I've seen for an M35 was $5,700 Aus and that's abit excessive just for suspension in my opinion.
Wish I could read Japanese, it would help with a lot of things.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
