Me too Mick, me too! I am itching to see how the GT3586R performs, especially with the 0.85 rear. I don't know of anyone else in Australia using the same combo' as yet.
Realistically, a month or more... the new engine build isn't finished yet. Dump pipe has to be fabricated, a bunch of ceramic coating etc. It doesn't help that I like everything to look nice as well, so more polishing and ceramic coating etc. Then I have to bed the rings in, the list goes on.
Wow man, it is going to be all around monster compared to your old setup. Should have got a Super94 for it, probably drive similar (definitely not worse) and gives you the potential for 600kw lol
Sent from my GT-I9505 using Tapatalk
You cant help yourself can you :P
Haha well I did it to you, you ended up giving in, and how much do you regret it now that you did? :P
You know the answer to that :P
Best thing i have done to the car to date!
Haha you read my mind! :D
Another sucker right there ^^^ :laugh:
f**king broke back bromance right here!
  • Like 1
The FP HTA GT3586R will be the fourth turbo I've tried since I purchased the car (99% stock) in 1999 - it was less than 5yrs old at the time.
The aftermarket turbocharger industry has changed a touch over the years. I've watched prices drop by more than 1/2, available options more than double, and response and peak power rise to levels once unheard of!
I won a dyno day at the then Croydon Autosports a few months after I bought my 33, just over 200kW at the rears was enough to pip about 20 other competitors. For those that remember him/his car Mario bought the once famous 'GTR700' from the same yard some months after I bought my 33. They wanted $75k for that R33 GT-R.... it was 100% standard.
Awesome :D
Be very interesting to overlay the old RB25 + T62 with the RB30 + GT3586R - it should be a bit of a mindblowing comparison.... bearing in mind they are both 62mm turbos!
Easy done, I'll be using the same dyno I've used for many years so I can load up my old file and overlay with the new one. Shaun (workshop and dyno owner) probably still has dyno runs from the previous turbo too - very old school Garrett T3/T04E combo'.
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
