My new engine build is finished and I'm currently 300ish kilometres through a 1000klm run in period - engine builder/tuner mandated run in period. I'm currently stuck with 4,000rpm and approx' 2psi boost limiters. Early seat-of-the-pants impression is very promising, with the boost limiter interrupting proceedings in a flash! During the run-in tune he gave it a very brief squirt up to 7psi, it took less than 2000rpm.
The engine bay is filthy dirty at the moment (by my standards) I'll eventually get around to detailing the car once the remaining new parts (billet TB, K-Sport BBK, Nismo diff' and IQ3) are fitted.
  • Like 2
Dodgy designed turbo leaks oil like a tanker.
They won't warrant it as they dont make them anymore and they flat out blame the oil leaks on crank case pressure not their product.
Its a well known thing about them in the evo world.
I know of 4 other people with this issue with as little as 1500km on their turbos. Took my stock turbo to be modified at GT PUMPS & he currently has 4 of them that are leaking oil the only fix is to convert them to Journal bearing.
I spent $2700 on a turbo that done 3000km and isnt worth its weight in scrap :(
VERY disappointed as it took them months to build it and its f**ked in less time than it took to be built :(
Thats no good Mick, sorry to hear that, i hope my core doesn't do that as its a 10mm bb cartridge they make. Im having trouble getting the comp cover off mine. Anyone have any ideas as i thought once you unbolt the rear they should spin fairly easily. the fabricator is being a pain in the ass and wants nothing to do with it which makes me think he's done something to it when he welded the 90* bend on it
FFS buy my HKS powered yellow Stagea and light match in the Emo.
You know it makes sense having room for a pram and roof racks and a tow bar.
Super cheap discount for you too Mick!!
Looks good matt, bet you cant wait to get sum boost into it.
What exh housing you end up using?
G'day Andrew. Thanks mate. Yeah I'm super keen to see what it can do once the shackles come off!
I went with the FP .85 V-band
Heres what FP wanted to charge me for ONE o ring. Would be over $100au once converted US with paypal. I said thats ridiculous and asked for the size so i could get one locally but she said she doesnt have the size.
Typical US freight prices. You could try ordering it through one of many FP retailers and see if their freight charges are better, or use a freight forwarding company.
Nice, ive recently bought the same .85 housing to try, see how it conpares to current .82 garrett
those padded envelopes have really gone up in price..
just take your existing one to a turbo shop and have them piece it together for you.
seems the customer service of these guys have really plummeted
  • Like 1
Its all good went to a bearing joint and got one for $2. Big difference in price. If anyone on the gold coast reads this stay away from all performance garage. He's the reason for my dramas.
Cool! Once you've fitted the FP .85 our turbo spec's will match. The slightly larger housing should result in a small increase in top end.
Your RB30 combo has the 26 head doesn't it?
Let me know how you go once the new housing is up and running.
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
