Had the oznats over the weekend...
The car wasnt finished but just bolted it together... need to finish the interior and the front end , side skirts etc etc
Have to sort out my traction issues. Even with slicks i cant keep the power down. If you listen to the video im constantly on and off throttle and constantly loosing traction. even on the well prepped drag strip. any ideas would be great
video-1477097823.mp4
  • 7 months later...
On 25/08/2015 at 11:21 AM, Adz2332 said:
Long time coming but i got the car tuned, again. This time by a different tuner and to say it was tuned badly seems an understatement.
Havent had a chance to take it out to the drags again but have a drift prac day coming up in 3 weeks i think, so will test it out then
attached the new dyno print out
Who did the good tune ?
On 28/04/2014 at 0:51 PM, Adz2332 said:
stripping down the engine at the moment. removing things i dont need and getting it ready for.....
This.....
HTA3076R
also have a trial waste gate, dump, 6boost mani and screamer
10307394_10154088892755215_2184393771918
I wanted an FP HTA turbo before i got mucked around and sent a wrong turbo.  Nice to see it made plenty of power
  • 4 weeks later...
Put on some AR1s  285s all round and went and did a track day at mallala on sat.
was a blast. car went really well and the tyres were excellent for the price
i now need to upgrade the brakes as it boiled its guts out and lost all braking by the end. and also get some coilovers to
But was a great day!
  • 3 weeks later...
forgot to add.
had the VCT sorted working and tuned before the track day. You could see a bit of a difference on the dyno print out. but the butt dyno it made a hell of a difference. felt boost came on so much earlier and smoother. made the car so much easier to drive and so much quicker all round.
Funny how much it changed the whole feeling of the car
  • Like 1
  • 1 month later...
currently getting parts together for a rb25/30 build.
so far have a 30 block
my rb25 head, 6boost main, plazaman plenum, 1000cc injectors, computer etc etc
have to work out, pistons, bearings, rods etc
want to go big to hold 450kws ish...
any links or builds i should look at?
No, but we did one earlier this year so I've got a fairly good handle on what's needed. We used a stock bottom end (found an RB30 bottom end that had never been run).
It's the little things that you'll need to sort out:
- the oil feed for the VCT (the machine shop we use has done quite a few 25/30's & knows what's needed),
-what you do with the cold start crap and associated hoses (we removed pretty much all of it, and don't regret it),
-coolant lines on the intake side (once again we got rid of some),
-the oil drain / breather on the front exhaust side (RB30 block doesn't have the port for this),
-engine mounts / raising the bonnet (we kept the mounts stock, and raised the rear of the bonnet with some spacers under the hinges - also had to ditch the strut tower brace. Didn't want to lower the mounts as we have an extended sump, and didn't want it to be the lowest part of the car),
-the dump pipe (had to cut & extend ours, as turbo was now 40mm higher),
-you'll probably need a new RB30 water pump (the RB25 one has a slotted hole, which doesn't quite cover the water channel in the block - ask me how I know),
-the intake piping (once again because the top of our engine was higher, we needed longer intake pipe silicone joiners on the intake pipes, just above the exhaust manifold. Had to buy a 1 metre length as we couldn't find the right size in smaller lengths),
-you will need to buy a second timing belt tensioner & a longer timing belt
-intake side wiring - we had to make up some extended loom mounts because the head was now higher.
I can't think of anything else at the moment. If you want the machine shop's contact details let me know - he's in Pooraka. We are loving the engine - the torque delivery is beautiful.
looking at some budget coils.
Monopro Type Coilovers- Street/Track
http://www.option1garage.com.au/HSD.htm
or
http://www.option1garage.com.au/BCRacing.htm
BR Series Street and Circuit Coilover
  • 1 month later...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
