Hey guys, I have a 32gtr. The engine has everything under the sun done to it. It has -5s and makes great power. The problem is not great power figures it's low down power out of corners. I'm thinking this problem may be due to 280 cams in it. What do you guys think? The car has been very finely tuned so I don't expect this.
https://www.sau.com.au/forums/topic/426530-need-more-down-low-for-the-track/
It is a2.6ltr, 98 octane fuel with octane booster the tune was done by dr drift then by cosmic performance.
It sound like people are making great power and response from the stock cams. But I'm not sure they would use all of the rev range up top that the engine was built for...
Cheers guys!
Have you considered using the next gear down, to keep the engine in its power band?
What if you're at 4000 in second... Not quite enough on a massive cammed 2.6 with 5's to really get a wriggle on.... You're not gonna go back to first are you?
The boys pretty well have it nailed for you mate. Jew brew, smaller duration cams, this is depending on what has been hacked out of the head as well, a good free flowing exhaust, a good cold air system and some time on the dump with a set of cam gears. Failing that, a 6266 is a good option.
Cheers guys!
So what are you spinning the motor up to exactly? Because realistically you wouldn't build a motor to spin to 9,000rpm+ and then put -5s on it as there is no need.
My stock cams were fine to 8500rpm for example with -5s... Power had not fallen off at all.
280s are madness either way for -5s, terrible match
Potentially get flamed for suggesting this. Oh well here goes anyway.
Guys above I believe are on the money. DO this ^
do you run a Torque/split controller ?
considered replacing your OEM G sensor ? with a Do Luck Tarzan G or the Midori unit.
the mines 34GTR is so responsive coz of the diff ratios despite the 2530's on RB26. Either a 4.11 or 4.4 ratio would be off tap, obviously the top end end would be compromised a bit, but who cares
mines GTR response is unreal
Edited by discoPumpkin
You are all missing the point. Odds are it would be cheaper to get the thing through the corners quicker...then you have more revs on exit and more revs means more power.
So what suspension and tyres/rims size are you running. Cams or no cams -5s can work perfectly well on a 2.6L so if the thing is laggy on exit I think you need to get through the corner quicker
Totally agree.
Driving style is another.
How long is a piece of string.
If your at a tight track you may suffer but at a faster track it may be perfect. Set up is about compromises and wont be perfect for every corner. Just keep trying to get your lap-times down. I would be listening to Roy before i go touching the engine.
Yeah but massive lift big duration cams (280*) are made for a gt42 45 55 ect sized turbo. Just not really suited to smaller twins. Twin 3037s and a 1/4 drag strip is a different story. Tomei type b's are tried and proven with -5's on the track and even a drag strip strip. As R31Nismoid said -5's and 280* cams are just a extreme mismatch. I do also agree with roys comment to a extent as well.
Cheers josh
omg, OP never once stated getting a bigger engine was an option, oh and the RB26 has to be one of the best know motors for track use for it's mid to top end power, reliability and revs.
I agree with Jim and changing the diffs, and the other guys in swapping the cams, and finally making sure it has good soft tyres for grip to enter the corners fast as poss. That will make a big difference to response
Thanks for all your responses guys. I know the cams are to big (they were in when I got the car). I run semi slims and custom coilovers on the track. I'm not sure that corner speed is the problem. Eg on sandown in the tight section it feels like I should be cornering in third but find that to get good power down out of the corner I need to be in second. Second I need to rev the car to 9+g and third is a bit sluggish out.
Would my engine specs help?
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
