To tight to buy a new thermostat housing, so simple, I just made one.
Also started to extend the top timing belt cover, it had a crack and a piece missing so it was easier to cut the small section out and replace it at the same time.
  • Like 4
  • 2 months later...
Bit of an update, had a small side project for my boss in Melbourne which turned into a bigger project fixing a previous dodgy repair.
The front section of the rail had been repaired before and been fully sealed up not letting any water that happened to get into the rail escape out the bottom.
So the rail rusted from the inside out.
When i cut the outside of the rail out i found it had a welded inside of the rail on the inner.
After removing the inner plate i was left with this.
From this point I cut the inner out and fabricated a new rail and repaired a few more rust patches.
Sorry no photos of the finished repairs I was to keen to get this thing out of my shed.
Now back to the hatch, not a great deal has has happened except planning and procrastinating but I have started seam welding some of the body.
  • Like 3
  • 3 weeks later...
Got a few more things done.
Checked it see if the power steering lines could be reused, will need to modify the hose on the power steering pump.
Replaced the front wheel bearings.
And started getting some of the suspension parts striped for painting.
  • Like 2
  • 3 weeks later...
Well today I thought I would touch base with the engineer to see at what stage he wanted to see the car next only to be told by the receptionist that
he has recently lost his VASS accreditation. Looks like the $1000 I have spent with him is a total loss and I don't even know if he has any documentation
he can give me to pass onto a new engineer when I find one. So now the search for a new engineer start and hopefully find one that is happy with the
build so far.   :banghead:
Edited by turbo76lx
Shit mate, that's no good. If your current (now ex!) engineer doesn't recommend someone for you PM me and I'll track down the details of another engineer who comes to Shepp fairly regularly. We sold him a Benz not long ago and I spoke to him about engineering my car with the RB30 in it. He was pretty confident he'd get it through whereas others just instantly shit canned the idea so he's at least open to a little lateral interpretation of the VSI regs!
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
