Hey all.
Does anyone know who stocks Nissan Matic S auto trans fluid? I am assuming that most Nissan dealers would but I am also assuming that they will charge typically ridiculous dealer prices for it. Does anyone else in Aus stock it?
Cheers
Al
https://www.sau.com.au/forums/topic/428533-where-to-get-nissan-matic-s-atf/
I don't know if you can even get Matic S from Nissan Aus; last time I asked, I got a blank stare.
Any reason why you wouldn't use Matic J?
If you're after a full Synthetic Nissan suitable ATF; Nulon Full Synth is excellent.
Many NM35 Stagea guys have been using it for extended periods without any issues, and on high powered cars.
You can import some from the Us of A. But it will be shipping not air freight, take forever, and most likely be expensive.
Or you can go down to your Nissan dealer and buy matic J, service your car, and get on with life ;)
ANY nissan dealer can/will get nissan matic D/J (or XYZ!) for you. . .if i remember correctly the last one i got was approx $60 for four litres
the aftermarket equivalant was around the same price
Edited by StevenCJR31
Where are you using it then if not to service the gearbox?
Nulon synthetic is cheaper than Matic J...
Options include, but no limited to
Putting under the rear wheels, so skids can be achieved.
Running it in grandmas 87 corolla, that hasn't seen a service since GW Bush Snr toddled through Iraq the first time
Running it in my daily shopping trolleys manual gearbox because race shift fast change.
Theres also a Penrite Fluid which meets Nissan Matic standards, I have linked to it below; Also which kit transgo kit did you buy?
http://www.penriteoil.com.au/products.php?id_categ=3&id_products=336
The Nismo Shop do it pretty reasonable if you buy a few bottles at a time, shipping is about $80 for 4 bottles/3.8L. If you're in WA I'm happy to split shipping with you.
http://www.thenismoshop.com/NISSAN-Matic-S-J-Automatic-Transmission-Fluid--999MP-MTS00P_p_304.html
Edited by Magic
I have just found a place here in Perth that has a 20L can with a dent in it so they'll give it to me for $50!!! Normally $350-$400. Score!!!
  • 2 months later...
  • 1 year later...
I thought they didn't ship internationally?
"This product ships UPS ground only. WE CAN'T SHIP FLUIDS INTERNATIONALLY!!!!!!!!!"
BTW I was just quoted $350 + GST ($385) from a Nissan Melbourne dealer for a 20L drum of Nissan Matic S. I want to use the right stuff but ummm... yeah, nah. Nengun sell it for $190 AUD a 20L drum but my account doesn't work and I don't know if that's shipped or not. I can also see it on Alibaba Express direct from Japan but can't get a price without an account.
My understanding is the Matic S, while a replacement for the J, is really only required for the 7 speed autos?
Mine being a 5 speed I'm going to ask if they have Matic J in stock, how much and can I use that.
Makes me wonder how old their stock is given S came around circa 2008-2009?
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
