Well, with 30k Euro in the block, crank, head alone, you aren't going to get there with the $4000 euros left in your 50kAUD budget. Shit, your not going to even have an engine. Still need rods, pistons, All bolts/fittings valves and valve train gear, dry sump system, manifolds, turbo, gates.
Thats before we get to clutch, GB, shafts, diffs.
Budget well and truly busted.
e30K is $44k aus.
now calculate redability of parts. shipping, price of living you are pushing it to the very least $75k AUD.
labour
tax
aussie car dream boats who over charge on EVERYTHING
now, we are in the $200k AUD mark already.
Lol didn't know AUS was this expensive.
Iet's stop talking about the $$$$$ as I already have the quotes here which are around 50K for everything . No need to jump in and go offtopic for this. Engine rebuild is max. 30K. Been quoted over and over. It's not that expensive. It's not a R35 GTR. We are talking here about a R32 GTS4 with a rb20det.
Edited by JDM_R32_R35
Don't forget all those fuel pumps!
Hang on. You have already been told what it will cost. So therefore the spec of pretty much everything must be known. So why are you asking questions?
By the way, a 1000HP RB20 is probably doable. It's only the same as a 1300HP RB26.
BUT IT WOULD BE SOOOOOO POINTLESS. There is no point. What could you possibly do with it? A 1000rpm power band at 11k is going to be sooooo much fun to drive.
That same amount of money, spent on good cocaine and hookers would benefit you so much more.
If you already have a quote, what in f**ks name are you hoping for here?
You are not going to achieve 800kw with a 30K euro motor, at least not more than once. Australia is expensive, but it's perhaps 10-20% more expensive, and I bet we do RBs better (and probably cheaper) than anywhere in Europe.
It's not a must to reply.
no comment again on this.
Yeah,
Lots of stress on the body when you're putting out 1000hp....especially in an older & fragile R32 chassis.
Chances are the panel gaps will get warped.
To achieve 1000hp with an RB20, you're going to need to stroke out the block to 2.4L (go with I-BEAM conrods as they can be lighter yet attain the same strength as a heavier H-Beam) and cement fill the block for high boost application,then strap on twin HKS GT3040 turbines, convert to solid lifters, full E85 conversion and fuel system to suit, modify the cylinder head as necessary (including a set of drag spec camshafts) and optimise port design etc etc, and lots of other stuff.
Done.
  • Like 1
BMW got some manky 4 cyl 1.5L iron block to hold 1500hp years ago, reliably too, they got at least one race out of them...
I say go for it. Post results.
wow. . . send me the money(aus dollars not euro monopoly money) and i will get a nice 25/30 engine for you(engine only), whack a rb20 cam cover on it and no one will know
google the britten motorbike, he made all the parts at home, you could make a new head for the 20 which would be awesome, if you stroked it down as zebra says you could copy the design of a hayabusa head
don't worry about the panel warping thing, if that happens just paint it orange and jump in and out of the windows ;) golden
lol at euro being monopoly money.
HAVE YOU SEEN SHITTY AUS DOLLARS?
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
