Well when I first got the AEM, BEFORE I had any suspicions about it's accuracy, my tuner actually commented about how accurate it was. Said it read dead on exactly the same as his. I'm only suspicious now because of how rich it reads, but that could well be my tune.
i'm sold, techedge it is
http://wbo2.com/2j/2j9.htm
So all i need is 2J9 + cables + sensor? (17123)
Yup.
it is a good idea to grab a LX1 display to go with it if you can afford it. that way you can be sure the input settings are correct in the software on your ecu because you can compare it with the external display, also if the car leans out when your into it you can see it on the fly.
I got this depo gauge...seems all right has Bosch sensor..
Started reading lean, turns out my fuel filter needed replacing...replaced fuel filter now wideband reads error...tried to calibrate it but no response.. :unsure:
Pretty sure sensor is still fine , if unit is dead can I just get the techedge so I can link it to my adaptronic?
start again and get a new sensor with the TE. peace of mind is a good thing and they are not very expensive anyway.
I am pretty sure depo is a china brand.
Not sure, Says Japan on their site, was about the same price as AEM so figured it was an entry level unit...hopefully I can get it up and running again..its a cool little gauge but can't find the instruction booklet to figure out why the error code...
Good timing for this thread to pop up... I'd just decided to drop some coin on a wide band unit that I'll have wired in permanently, when I noticed this thread.
I had my eye on a Koso unit from the states, but after reading Guilt-Toy's advice I think I'll go for an 2J9 Tech Edge unit with LX1 display.
Edited by Ryno
Crunch the numbers and find the price difference between the 2J and the 3A models, remember the techedge site doesn't quote gst, the initial pain to your wallet will soon pass and it's much cheaper to buy right the first time.
just curious on why people prefer the tech edge over all in one units such as AEM UEGO, Innovate MTX-L, LC-1, PLX?
Is it because it uses the BOSCH LSU 4.9 sensor instead of the LSU 4.2 sensor?
I bought mine mainly on reputation, a few of the tuners I've spoken to use them, and have told me the people who design and build them know their shit and they are built to a standard not a price. As for the all-in-one gauge and driver, I would have liked a gauge but this was only a secondary consideration, accuracy and quality took priority, after all this is a tuning tool not another dial to rice up my dash. Also the driver will accept uego and multiple bosch sensors.
Mike.
Edited by Missileman
^ fair enough, I don't use widebands to rice up my dash either. I've always used all in one units to street tune my car and my friend's cars, one thing I've notice is that there's always a little lag time between the pedal being depressed vs. the readout from the widebands I've used.
I posted the nistune graph in your other thread and you saw how little lag there was when I jumped off the throttle at 60, about 1/3 of second lag, and that was at minimal gas flow. I believe the techedge gauges would read at the same speed/lag as nistune.
bosch 4.9 mounted before the cat
See how we go :)
I've recently just installed a AEM UEGO gauge on my mate's S15 just right before the cat (japanese downpipe already had a pre welded bung). I'm plugging up his Nistune either this weekend, just waiting to see if his missus will let him out for a day haha
ok....reasons im getting an error or code "03" (as it appears on my unit)...have tried to recalibrate but pushing its button does nothing....
bosch sensor has barely 3000km on it...originally had this problem with not getting enough power, but I fixed this when I rewired it...unit is getting 12v or thereabout and it was working fine until I changed a fuel filter, I also drained the tank a few times...none of which should have any effect on the wideband I thought...i did have it running too rich for a while, have fixed that... pulled sensor out and looks clean...
Anyone got any ideas here, I'm stumped ?
  • 5 weeks later...
Have you check if the O2 sensor is heating up?
this, i have a faulty unit and even though the voltage was being sent to the sensor it would not heat up. you can light a cigarette if it works =p
Take the sensor out of the exhaust and feel it. If it gets hot quickly it is working. Careful you don't burn yourself...
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
