We need a nice sunny day for photos.
Its been fairly nasty blizzard type weather up here lately.
But, yeah its ready to go, i even took it for a spin around the block a few times to warm it up.
Ive been driving the missus Volvo V70 for 6 months, so its real nice to get in it again.
Ooh, thats nice.
Ok, so ive finished polishing fully now, no more touch ups, i cant see cos i never get a chance on a sunny day. So it will have to do for now.
Its washed and ready for the 4 layers of stuff going on.
Lime prime to prep the paint for wax, hard wax, soft wax, sealant.
Its nice and cold out there at night, polish and stuff doesnt dry, so you get ages to work with it. But on the other hand, wax that normally takes 24 hours to cure will take 48.
That's Awesome! ^^^
Right, that's it Mik, you have permission to paint the SkyWagon the same colour as your car. (now you've had practice) :laugh:
Ill spray your car no worries, as in just the spray gun and you can do the other 180hrs or so of stuff.... :laugh:
But realistically, youd want to do it to a car with no rego, or do a quickie.
Thats just: pull of some bits, wash, a light sand, tape up, dust, wax&grease remover, prime, solid colour (gloss, no clear), a quick polish, done.
No bodywork and no idea how long it will last, but an easy way to change the colour.
And my compressor needs a service before i use it again.
Anyway, i should be done soon, prime lime tonight, and maybe the first wax too if i can.
Thanks guys.
Photos look a bit better than it really is, but its still good, im very happy with it.
Mainly the colour, its really just the way i wanted it, and the first time i saw it glowing in the sunset....... wow. :wub:
  • Like 1
Thanks guys.
Yep, pretty sure I heard your mind Fap. :laugh:
Looks better in person I reckon.
The colour change depending on available light is mad and it's hard to capture the true colour in a pic but that evening light worked wonders on the pearls within.
:thumbsup:
  • 1 month later...
Well i spose its time to get into something else like the interior, its pretty shagged.
Some led lights, cheap and easy:
post-89755-0-28919100-1409635318_thumb.jpg post-89755-0-44784500-1409635350_thumb.jpg post-89755-0-41245600-1409635369_thumb.jpg
The boot, i just plugged the green and earth into the light socket.
I will use the rest in the cabin with the controller and maybe a bit of a work light under the bonnett.
  • 1 month later...
  • 4 months later...
Soldered broken joints in the window relay, while i swapped the door trim to one that isnt chopped.
Fixed my other trims, no sign of chopping out for a window net anymore. ( window net was a stupid idea without a rollcage )
Put in a smaller intercooler, the big one was not helping with power, it just blocks air to the radiator.
A piece of corflute to block the last gap.
post-89755-0-25373900-1425693636_thumb.jpg post-89755-0-46864700-1425693642_thumb.jpg
I got another pair of seats that have tighter rails than mine, but some bits are worse, i will make one good pair from it all.
Fender braces and a new oil temp gauge coming soon.....
  • Like 1
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
