  • 1 month later...
My 32. Had it for 9 years and not a cent spent on the exterior.....yet.
1960881_10152054375322734_901571917_o_zp
1781358_10152054498867734_1332399294_o_z
Beautiful car!
Whats the clips on the boot of it for? like what is it there for, what have you removed etc? Do you still run struts?
Where did you get the clips from also?
Thanks
Beautiful car!
Thanks
Thanks, mate.
The bootlid is an aftermarket fibreglass item with some kind of custom lip built-in that came with the car from Japan. Being much lighter than the factory item, the boot lid doesn't sit flush unless the clips are on. The original clips that the car came with from Japan were stolen when the car was @Australian docks ages ago. Took me years to find a place that had replacements -
http://www.protex.com/toggle-latches/medium-duty
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
