Thanks :blink:
I was going nuts with having a black car that got dirty sitting in the garage, SO I made a cover system that is easy to use, pull it up,drive out, drive in and drop it down, too easy
Mick's blue and Dave's red cars come up great in a photo and they have some great shots :cool:
Thanks for the kind words Pete, I love the cover idea, I might have to copy that one :D
Well deserved. :yes: :yes:
The cover works well and I used a showroom quality cover that is very soft underneath, As the cover does not get dragged over the car and there is no wind to worry about in the garage it is not a problem on the paint.
If you ever want to get a better idea how I set it up let me know ans I will PM you and get a couple of pics to you. :thumbsup:
I've been privileged to have known just two GTRs that have arrived into Australia as brand new.
Both are BNR34s
Both are V-spec II Nurs
Both still had plastic on door cards and seats
Both are in Sydney NSW
And one of them Bueller is yours. Again congratulations!
Both are BNR34s
Thanks, congrats on your 32 N1, getting closer to the complete set
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
