Hi all,
Thought I'd ask the knowledgeable people on SAU this.
I looking for a good turbo for a Toyota 2 litre straight six (1GGTE). Basically chasing 220rwkw + without excessive lag. I would just buy a 2530 but don't really trust second hand turbo's, especially when new ones are cheap.
I have narrowed it down to the Kinugawa TD05 18G and the TD06 SL2 18G.
http://www.ebay.com.au/itm/271264269898?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.com.au/itm/281156507798?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Basically I'm looking at turbo's that would normally be used on an RB20.
What do you guys think?
I assume you are going T3/external wastegate setup? I'd go a Kinugawa TD05-16G - much better spool and response than the 18G and well capable of 220rwkw, there is virtually no difference in flow potential between the two compressors.
An EFR6758 would be amazing on it (aside from only being T25 flange), or a GTX2863R - if OP is willing to splurge that much. Precision don't really do much in the right size range.
We definitely had issues with boost creep with an internally gated Kando TD05-16G on an SR20DET, but it was easily fixed with a bit of porting - the OEM Mitsubishi TD05s even had the same issue if you opened the exhaust up too much. I think OEM Supra and RX7 turbos can have the same issues as well, even some HKS internally gated turbos have been known to boost creep... its not that unusual with an internally gated turbo unfortunately.
Here is are dyno plots for the 16G I tuned on a stock SR20DET, just did some porting to the wastegate port:
They might work fine on the stock map, but wind them up to maximum flow and all the flaws become evident.
Internal gates have never been a great design and generally flow like crap, as well as upsetting the main exhaust flow through the turbo. BW has taken a step in the right direction with the efr but at nearly twice the length not many of us have the room for one. A hidden external gate off the housing is the best option imo.
Thanks for the replies.
I don't know what to do now :yucky: .
As I'm going to be fabricating the dump and manifold myself I guess I should go external gate then, I just don't want to go through the extra expense and hassle of it if at a lowish power level of say 220rwkw it makes no difference between IG and EG.
Because the stock twins are only good for 190rwkw max, even then I have only seen 1 car make that on the stock twins, most make 170-180.
I would like 230rwkw or so, figured I would upgrade to something that would make that power pretty easily and have the potential to make alot more if I want to later down the track. No point chasing 270rwkw or more now as the stock motor wont handle that, and to be honest I would like to just get the best out of stockish motor.
Cost wise it would end up been a lot more expensive getting the twins highflowed, I would guess around $1500+ to do both? That plus dump pipe fab, it'll end up costing about the same as going single.
HKS made a 'highflow' version of the stock turbo's but they apparently are only good for low 200's, so not exactly a massive improvement over the stock ones.
Plus the whole tiny CT12 twin setup is so nasty on those things. The exhaust manifolds are nasty, the turbos are nasty, the dumps are nasty. A single with modern aero and some room to install a decent manifold and dump would have to be umpty bazzillion times better.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
