Well that upload speed is better than mine...
I'll be on probably before 8PM as well.
Everyone who's jumping on tonight, post your upload speeds. Currently 89cal is host till someone beats him ;P
Wow nice speeds. Looks like your next door to your exchange huh. Edit: ianjb is host
on a completely unrelated topic that i wont say anything more about beyond this post.
You do know that an SEO related link on this forum is doing nothing, if not bad for your SEO?
net cap lifted today. I will try to jump on 8pm. Curious: if private session is up, how to do we join? need to be invited.
+10000 to fistfight rampage. will bring knife and nightstick. (both are 50% of the reason i play GTA5 lol)
have to get invited
new house being built is plugged into the NBN....yay
anyway on topic, what do people wanna do
freerun rampages
races for lotso cash
well organised missions (fun when your all on the same page but little financial reward)
ect
Still reckon Boneyard survival is the best guaranteed money maker and experience getter. Hide behind shed, pop out shoot 10 waves of piss easy enemies = 20k. Takes about half an hour per survival and you just keep repeating it. You also get fk loads of free guns from it that you can use in freemode, though they disappear when you next log on.
1. Fistfights (separated into weapons/no weapons)
2. Races down the drain with 8 people. mad fun
3. MISSIONS (survival, proper missions)
4. Deathmatches
can't wait!
and yeah birds good point, the first time me and some mates discovered we get to keep the weapons once out of survival, was GOLD!
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
