People who get all road-ragey at you when THEY'RE the one in the wrong. Like the guy who felt the need to gesture out the window and swerve all over the road and point at the speed camera because I dared to come up behind him doing 80 in a 80 zone. He was doing 60. And no I didn't tailgate or anything.
Nothing makes me want to ram someone off the road, grab them by the throat, and explain to them why they're a f**kwit more. If I was the violent type. Which I'm not :P
This is why you should keep used spark plugs in the centre console lol
People who stop 3m behind the white line at a red light.
People (two or more different people), who park on a suburban street (say, maximum 2-3 lanes unmarked), on opposite sides of the road, right at the entrance of the road- thus creating a bottleneck in/out of the road - too lazy to park that extra 5m into their driveways (I found out they were too lazy because the morning after I left a thinly-veiled note on their windscreens, cars were magically parked in driveways/only on one side of the street - they had continued their previous behaviour for MONTHS prior, and now, not a single repeat).
Solution is to surfboard wax the message on their windscreen. The inconvenience of getting that off will teach them not to be lazy lol
This conversation has stayed with me as a reminder as to the calibre of people on the road.
After I nearly got wiped off the road by someone trying to merge on top of me we pull up to a set of lights, windows down.
Wat mate?
Me: it's called a blind spot, maybe you should check it sometime.
Him: if it's a blind spot, then how am I suppose to check it?
All I could do was laugh and shake my head in disbelief.
drive off, he then pulls into my lane and in front at the next set of lights. Then tries to fake reverse into me.... Sigh.
This is why car manufacturers really supply tyre irons (for other driver adjustment) in the boot lol
21. Jamming the passenger door into the ground then getting into the car, putting more weight on the side of the car and jamming the door deeper, then pulling hard just to get it unstuck. Extra nasty if the door is stuck against the concrete sidewalk
22. Dragging shoes and bags over the door sill plate, door trims and glove box lid while getting into the car
Technically this ones an IQ test: Jamming the seat belt buckle into the centre console since they can't be bothered looking where the clasp is
This ones for the druggies out there: Playing with sun visors or power windows non stop
23. Dragging stuff over the boot loading lip or bumper bar while loading and unloading
24. Not closing the windows when exiting someone else's car.
25. People who don't learn how to reverse park their over sized suv/4wd, take freakin ages doing it and still fail to park properly.
26. People who don't wave after you've given them space to change lanes, pull out of driveways, side streets, etc in traffic. Unappreciative twats.
27. People doing under the speed limit in a T2 lane with no passengers in peak traffic.
28. People sitting in your blindspot constantly when merging into a 1 lane, clearly knowing they have to back off so you can merge, but decide to at the last second within inches.
Slamming car doors, lowring the bonnet then pushing it closed, other people leaning on your car, camry/corolla/kluger/accord/jazz/avalon drivers and people who can f*#@King use their blinker.....
  • 3 weeks later...
Hehe...
Just doing fellow cabin members a favour.
When an ambulance is espied coming up behind but still far off, I recommend flashing the car in front of you just before pulling back into an undertaking lane.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
