For use guys that are running a flex fuel set up. Which content sensor are you using and what did it cost? I can get a genuine gm sensor which is the flow through type for around $200. I have not seen to many more for sale that are available locally
https://www.sau.com.au/forums/topic/434195-which-ethanol-content-sensor-to-use/
  • 7 months later...
If I was to use an Adaptronic Select plug in ECU will this be compatible with it?
Yes, but remember adaptronic ECU doesn't truly do flex fuel - as it doesn't have the capability to blend maps like say a haltech as such.. it just adds/deducts timing and compensates fuel based on rpm/load.
good enough if you're mainly using E85 and pop in the occasional 98 or blends
Do you just pop the sensor inline in the return line then call it a day?
yepp and connect the sensor up.. if you're really tight you can connect the output to a digital volt gauge to measure ethanol content.
0V = no ethanol
1V = 20%
2V = 40%
3V = 60%
4V = 80%
5V = 100% ethanol
  • Like 1
I was reading a paper linked on the adaptronic forums that talked about ethanol content and knock resistance - peak ignition timing for port injected engines is at about 40% ethanol content and additional ethanol doesn't benefit knock resistance. it was interesting reading as it means your fuel map needs to vary from 0% to 85% ethanol (to get mixtures right) but the ignition map probably only needs to vary between 0% and 40% ethanol content. (I say probably - I'm not a tuner!). So even blending maps may not produce a perfect result, although it would be conservative with the ignition timing on a partial blend which is a safe option.
quick question, I'm looking at adding an ethanol sensor to my Link G4 sometime before the end of the year. The wiring manual for the continental sensor shows a +14v output from the ECU to the sensor, but there is no such output of voltage from the ECU. I'm thinking this is just a power source from battery/ignition but obviously I don't want to fry the ECU so can anyone help me out.
I feel like this is maybe a silly question but oh well lol
0V = no ethanol
1V = 20%
2V = 40%
3V = 60%
4V = 80%
5V = 100% ethanol
Hmm.
But the sensors output a frequency, 50 to 125 hertz if I remember correctly.
The whole point of the zeitronix box is to convert that to a voltage. If you didn't need it why would people buy it?
Edited by Ben C34
Got a link to the thread mate?
Can't find it on adaptronic forums, i think it was one of the discussions on flex fuel. Here's the actual paper though (see link down the bottom to PDF):
http://dspace.mit.edu/handle/1721.1/69496
Your correct, use a +14v ignition switched supply.
Thanks
I figured as much, the wiring drawing just confused me because it shows a 14v supply straight from the ECU. Figured that must have been just a switched power supply, but wasn't real keen to blow up the ECU so had to ask lol
Thanks
you got a diagram of that mate?
also anyone know where to buy the sensor plug?
I have sensor here but not sure how to wire it...
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
