Why is this still unresolved? Almost at two weeks later ffs.
It's not unresolved. It's just that RBR didn't like the resolution.
But RBR have been testing meters under FIA observation in the meantime, and have "acquired a number of new fuel flow sensors and will work with the FIA during the (Malaysian GP) weekend to find one that is accurate to the satisfaction of both sides."
They're less likely to do it again this weekend because they have no real hope of keeping the Mercedes powered cars behind them on these long straights unless Renault has made big gains in their engine POWER spec - oops did I say power? I meant reliability - because those are the only changes allowed now, for improved reliability. yeah right... whereas in Aus it was worth the risk because it is a difficult track to pass on.
Edited by hrd-hr30
Slightly worrying that the sensors need to be tested on the car to find an accurate/acceptable one.
They are all tested then an offset applied (eg its 2% over reading or under reading or whatever) and then used. It is easy to say it should be perfect but nothing in this world ever is.
The sensor manufacturer says "52 per cent of its meters are with a 0.1 per cent accuracy reading, with 92 per cent within 0.25 per cent". As you say the offset is applied to level them out, so all cars can use the same mass fuel flow.
"the teams have accepted that when they are alerted to the possibility the sensor could exceed the 100kg per hour rate at peak flow, irrespective of what their own data says, they have to peg back their rate slightly to ensure there is no breach of the rules." Well, every team except one that decided to ignore it and the FIA when fighting for position with a more powerful car...
(quotes from http://www.autosport.com/news/report.php/id/112973)
Edited by hrd-hr30
Well it does because if it was a bullshit number you can understand why they reacted in the way they did.
EG:
FIA: "We now want you to reduce your fuel flow by 5%"
RB: "It was 0.2% on Friday your numbers are clearly rubbish. Get stuffed."
FIA: "Resistance is useless" etc etc*
* Yes I am likening the FIA to the Vogons.
Edited by djr81
EG:
everyone was in the same boat. Other teams adjusted their fuel flow during the race according to what the FIA were seeing from the sensor. Some even chose to run well below the sensor indicated maximum flow to make sure they didn't exceed it. Only one car refused to play by the same rules and the same calibrated/corrected meter everyone was using. .
Edited by hrd-hr30
Half expect RBR are willing to fall on the sword early and bring the BS out in the open. I hear what you are saying about others obeying...but for all we know RBR may have been the worst example being asked to forfeit 4% power vs lesser amounts for others cars.
It matters little, the fact that many cars were all winding back performance, likely to all differing levels then why even have qualifying or practice sessions. Just have a raffle and fit random flow meters to the cars and watch them jockey for position in a race as the FIA tell them to slow down or allow them to speed up all on different levels ...retarded.
I am no fan of RBR...but good on them for busing balls over this now and hopefully we will avoid the farce of inaccurate instruments hurting a percentage of th efields performance over a race weekend, because....lotter dip of erroneous sensors says so
  • Like 2
Kimi has made a great improvement in the Ferrari. Mercedes having tyre wear worries
Might be an interesting weekend after all
yeah looks like it was more than just the new braking system....
but it sounded like he was having tyre issues on the long run too wasnt he?
hopefully the ferraris can take it to the mercs!!!
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
