Why is this still unresolved? Almost at two weeks later ffs.
It's not unresolved. It's just that RBR didn't like the resolution.
But RBR have been testing meters under FIA observation in the meantime, and have "acquired a number of new fuel flow sensors and will work with the FIA during the (Malaysian GP) weekend to find one that is accurate to the satisfaction of both sides."
They're less likely to do it again this weekend because they have no real hope of keeping the Mercedes powered cars behind them on these long straights unless Renault has made big gains in their engine POWER spec - oops did I say power? I meant reliability - because those are the only changes allowed now, for improved reliability. yeah right... whereas in Aus it was worth the risk because it is a difficult track to pass on.
Edited by hrd-hr30
Slightly worrying that the sensors need to be tested on the car to find an accurate/acceptable one.
They are all tested then an offset applied (eg its 2% over reading or under reading or whatever) and then used. It is easy to say it should be perfect but nothing in this world ever is.
The sensor manufacturer says "52 per cent of its meters are with a 0.1 per cent accuracy reading, with 92 per cent within 0.25 per cent". As you say the offset is applied to level them out, so all cars can use the same mass fuel flow.
"the teams have accepted that when they are alerted to the possibility the sensor could exceed the 100kg per hour rate at peak flow, irrespective of what their own data says, they have to peg back their rate slightly to ensure there is no breach of the rules." Well, every team except one that decided to ignore it and the FIA when fighting for position with a more powerful car...
(quotes from http://www.autosport.com/news/report.php/id/112973)
Edited by hrd-hr30
Well it does because if it was a bullshit number you can understand why they reacted in the way they did.
EG:
FIA: "We now want you to reduce your fuel flow by 5%"
RB: "It was 0.2% on Friday your numbers are clearly rubbish. Get stuffed."
FIA: "Resistance is useless" etc etc*
* Yes I am likening the FIA to the Vogons.
Edited by djr81
EG:
everyone was in the same boat. Other teams adjusted their fuel flow during the race according to what the FIA were seeing from the sensor. Some even chose to run well below the sensor indicated maximum flow to make sure they didn't exceed it. Only one car refused to play by the same rules and the same calibrated/corrected meter everyone was using. .
Edited by hrd-hr30
Half expect RBR are willing to fall on the sword early and bring the BS out in the open. I hear what you are saying about others obeying...but for all we know RBR may have been the worst example being asked to forfeit 4% power vs lesser amounts for others cars.
It matters little, the fact that many cars were all winding back performance, likely to all differing levels then why even have qualifying or practice sessions. Just have a raffle and fit random flow meters to the cars and watch them jockey for position in a race as the FIA tell them to slow down or allow them to speed up all on different levels ...retarded.
I am no fan of RBR...but good on them for busing balls over this now and hopefully we will avoid the farce of inaccurate instruments hurting a percentage of th efields performance over a race weekend, because....lotter dip of erroneous sensors says so
  • Like 2
Kimi has made a great improvement in the Ferrari. Mercedes having tyre wear worries
Might be an interesting weekend after all
yeah looks like it was more than just the new braking system....
but it sounded like he was having tyre issues on the long run too wasnt he?
hopefully the ferraris can take it to the mercs!!!
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
