We don't have annual RWCs is WA. We only have to take a car for inspection if yellow stickered or registration lapses. As long as your car stays registered, you never have an inspection ...ever...
That's how things like this happen:
post-52031-12726087994694_thumb_zps20295
In all seriousness OP, you were better off buying a stock standard R33 if you were new to turbos. As with any car, you're not just buying a car. You're also buying someone else's pproblem.
I was new to turbos at one stage and guess what? I brought a very close to stock R33 and built it up from there. I was new to V8s too at one stage and guess what? Yep, I brought a stock one and have begun building that up.
People might be saying "but if you buy a modded one, you end up saving money on not having to do those mods" and I agree 100% BUT ONLY if you know what you are doing/looking for. In your case, you were fresh to turbos and you essentially brought a lemon. I can guarantee you 99% of the SAU members on here would not of brought the car you did, based purely on the "mods" that are done to that car.
Knowing what I know about turbos and V8s now, I can confidently buy a heavily modded example and know what to look for and how to maintain it. Unfortunatly, you've thrown yourself in the deep end and your only choice now is to fix the previous owner's problems. Consider it a hard lesson learnt and more than likely you'll end up spending more than the car purcahse price to get it to a level that would be acceptable.
Anyway, back on topic. You'll need to get a pipe made up which will mate up to the ext. wastegate flange and have it welded back downstream into the rest of the exhaust. That will reduce a MASSIVE amount fo noise when you're on boost. If your wastegate is leaking and considering it is vernting directly to the atmosphere (or should I say engine bay), that could also contribute to the extra nosie when you're off boost. Otherwise, get some mufflers thrown in by an exhasut shop if you want it quieten it down.
    • Hopefully you can just unbolt them, thank them for their service, then bin them and not replace them Apparently the sensors like to set them off with only minor impacts at low speed It looks like they do a delete kit for some of these, but, it is costly
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
