Amon please PM me the brand of cat that failed.
I would like to know this too if you don't mind, I've used magnaflow 200c metal cats on two of my cars with no problems, and they're fairly cheap on the scale of cats.
While there may be issues passing emissions with a 100c cat, I'd much rather take my chances of "maybe/maybe not" passing a test, than certainly being screwed running no cat.
It was a magnaflow 100 cell 4 inch body cat, the cells were all folding over.
I know its not top line but they are very popular.
Would be keen to know of a proven one that can flow 400kw and not die..
Thought id post the brand up, not defaming, just stating my encounter
No idea, Im near positive it died at last track day though. Hot day, all running fairly hot, full boost regularly
Did you pull any timing out of it for the track day? I wonder if it is just a track day issue or tune issue around the area you drive on the track?
I have a metal cat so I am interested what leads to the failure on some of them as you describe.
I figure a lack of advance could lead to combustion continuing out of the exhaust valves and skyrocketing EGT's but it doesn't sound like it in your case.
yeah I'd be extremely surprised if a cheap metal cat like magnaflow would stand up to the high temps and rigors of trackwork, think that would be asking alot of them. Street shouldn't be any isssue though. I'd be putting in a 3in race pipe during track use myself.
I know many who swear on SMB 4 and 5" http://www.smb.net.au/catalyticconverters.htm
Withstand hot rotarys
It would want to suck my cawk for that price. 3 times what I pay for a cat. lol.
  • Like 1
Any aftermarket car will be hard to pass EPA on 98, E85 would be easier as produces less NOx and other shit I don't know of lol.. I just I know it passes easily as my mate passed his 4G63T running E85 with a TD05, 272 cams, etc.. with DIY road tuning.
The reason I run a cat, is because I hate the smell of the exhaust, smells more pleasant with a cat lol
http://www.summitracing.com/dom/search/department/exhaust/part-type/catalytic-converters?SortBy=Default&SortOrder=Ascending
So many cats... Even with shipping some are very reasonably priced. Why we pay so much over here is beyond me.
  • Like 1
What i ran for years without issues, even flaming exhaust so lots of unburnt fuel went through it.....
http://www.cateran.com.au/cateran/images/Racecatposter.pdf
Compared to a decat, i notice a slight power drop after 7800 rpm though to 9000 so not bad on the restriction side of things.
Only thing is the port for the temp probe is a diffrent thread so i dilled the old one out and welded my own nut to it.
I need to go for an emissions test to get my engineer cert and iv been told to get a euro 4 cat converter has anyone heard of these or what have people used to help pass epa? I'm running e85-90 2200 injectors 270 duration 10.5 lift ect.
Sorry for hijacking didn't want to start another thread
Euro 4 are the best for passing tests but also the most retrictive and the most expensive.
Most people use Euro 3 cats as they are far more affordable, add E85 to the mix and your sitting sweet.
http://www.ebay.com.au/itm/OBD2-EURO3-Universal-Catalytic-converters-all-models-UNIVERSAL-FITMENT-/131059342207?pt=AU_Car_Parts_Accessories&hash=item1e83bedb7f
However if your runing a ECU, cams and aftermarket turbos, ive heard bad stories about the Full called in EPA tests, where they ask you to bend over and touch your toes while they put the rubber gloves on.....
If its not the full EPA test and just your engineer and he is approving your mods your OK.
Ive spoken to a a few kit car builds who have failed their engineers test for using high flow cats, but passed using the Euro 3 ones on petrol.
Edited by GTRPSI
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
