Hey guys, my funds have dried up for my 30 build but I got a free rb25de + manual and am going to drop it in my sil Im planning on bolting all my turbo gear and hope for the best.
ECU is going to be a z32, Nistune and will get it tuned. What would you say would be the safest power I can get from it? Id be pretty happy with 240 - 260hp.
Edited by Gameboy
Detonation will be your main concern with a high comp turbo engine. If you can get on e85 you may fine, or water/meth.... Keep the boost on the low side for longevity as the cylinder pressures will be massive.
It might be a good idea to swap to some decent head bolts and an MLS gasket while it's out of the car if you plan to push it hard.
Nah dont plan to push it hard but then again, whats considered pushing it? Id be happy with 230hp tbo. I know its a non turbo motor so im not expecting crazy figures. Anything would be better than the non turbo ca18 thats in there atm lol
Wow. How can you go from planning an rb2530 build to being happy with 230hp? :)
I just want it to be safe but if I can get it to be safe with even more power, than thats ok to :P Removed the old shitty CA last night will start putting the 25 in tonight. Its to freakin hot to do it during the day :(
Also, anyone who has done a rb in a sil kept the A\C? I love my A\C.
Yeah not using stock turbo. Will def get it tuned and might look into e85. I dont drive much so I dont mind the extra fuel consumption.
Edited by Gameboy
I cannot see the sense in fitting an iron block inline six for 230 horsepower , upset the chassis balance and cooling system for something than can be done with a twoish litre four cylinder . Still can't work out why people hate KA24 twin cam engines . Good enough for Nissan .
Maybe because KAs are ute and Bluebird (yuck!) motors.
ditch the RB if all you want is 230hp and just put an SR20 in it. That will make that power pretty damned easily
Putting an Rb into a Silvia is a nightmare as keeping it cool is difficult. An SR is no problems though
I have, kept the AC. I reused the CA condenser and fitted the lines to the RB20 compressor.
However, keeping the car cool is another thing. There's not enough airflow so each time the AC went on, the water temp shot up.
In the end, ended up ditching the AC and set the fans to push instead of pull.
well guys no point in this thread anymore as the timing belt snapped and bent valves. Shit happens. I got the engine for free anyway but still f**ked...back to my original plan now. Time to save for my forgies and finally finish my 25/30 build.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
