Hey guys,
I've searched and i can't seem to find what i'm after, so i thought i'd ask.
I was looking at buying a RB26DETT to put into my R34 GTT, But after looking around and talking with people. I've been swayed into looking at 26/30 builds. Only downside to this is i have no idea about them, the benefits or what is needed to build one/cost of it all?
If someone could explain the benefits of doing this and rough list of parts/costing. Not chasing huge power at the moment but down the track that will be the goal.
Cheers in advice
https://www.sau.com.au/forums/topic/437616-rb2630-help/
Use the NEO head.
NVCS Yo!
Really? From what i've been reading most people go against using the NEO head? All in favor of the 26 :O!
and way better comp comp ratio with stock pistons.
op, you have a lot of reading to figure out what you want.
I know there is alot of research left to do, but i can't seem to find any kind of basic guide/build threads out there i can see that would help me to a point. I'd say i'm aiming for around the 300-350 rwkw mark, being that the egine won't be in the car for awhile i'll have change to change mind and forge internals if i want to go down that path. Just need a push in the right direction to get the ball rolling
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7170735
Have you tried the search function or Google?
Here is the guide (in the very first pinned thread in the RB30 section):http://stevenwelsh.site.net.au/RB30_DOHC.pdf
and the third pinned thread in the RB30 guide is the RB30/26 guide.
Then at the top of the forced induction section you can see results including what was done for RB30/25 and RB30/26
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7170769
Why dont you work your original engine for your power goal?
Keeps the car legal, im sure your local police may not be too happy finding out its a RB30 with a 26 head in a GTT.
For the power your chasing its not worth the effort, use what you already have.
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7170772
I did try the search function, As i said. But thank you for being a smartarse and linking me the page and telling me other places to look.
Its Tasmania, We don't have defect stations ever ;) I figure i will want more power down the track its just a starting point, unless you can push the same amount of big power out of a 25neo as a 30/26
  • Like 1
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7170805
It doesn't cost a huge amount more to build a 30 as opposed to anything else, it's mainly sourcing the new stuff that's different and the machining that adds up. You end up adding a whole heap of extra stuff as you go.
My engine (which is still not finished) would have cost me $15000 I'd reckon. A lot of that has been upgrades that you would do on any performance build though- new dumps, new clutch, all new genuine hoses, new timing belt tensioners, etc, etc. The list is never ending!
No disrespect intended but I would learn a bit more about your car first before committing to a 30 build. Spend money on upgrades that can be transferred over to the 30 once you build it (turbo, injectors, fuel pump etc). Once you're used to that power then go the next step. Totally my opinion but it's your money!
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7171224
^ agreed 100%. You always end up spending money here/there.
IMO as others have said, stick with the 2.5ltr for now... Make your 300-350rwkw on it. Put decent suspension, brakes and so on into it and learn how to drive it.
While in the process of learning how to drive it with 300-350rwkw, build that 3ltr bottom end while you wait for it to pop (which will likely come eventually). All the engine ancillary parts will transfer with regard to injectors/ECU and so on if you think and plan ahead.
The ONLY thing would be to buy say a GT3076 for now so that it is not too laggy, once you have a 3ltr then put a larger turbo on there. You're only talking ~$1000 extra expenditure but if you get 1-2 years outta the 2.5ltr and so on, then you've had 1-2 years of a really bloody decent set-up with great all round performance and good power as opposed to putting a big turbo on first and it being laggy and you end up hating it.
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7172265
and everything is stock i built it stock rb30 200+ks engine and if u use a rb25 s2 head rips make a oil line for it on ebay like 80$
AND it cost 1000 $ to build rb25det oil pump, bearing set ,pistons and rings rb30et and head gasket and arp head bolts
Edited by r32_rb30det
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7173325
in my 12 years experience, my opinion now days is f**k it.. get a good stock motor and put quality supporting mods on it and quality tuning with e85 and make good strong reliable power.
ive built motor and blown them up, due to the silly little things that can go wrong, so financially im better off running an OEM motor with mods.
my car is proof of that, stock RB30 with 26 head, all supporting mods. 412 rwkw on 22 psi and it gets thrashed...HARD
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7173332
The only downside to E85 tune would be the lack of places that sell it close by to me. As far as i'm aware the closest place to me is 2-3hours away. So for now anything i do will be 98 pump tune. So you also think i should stick with the 25det neo and just support mods on that? The engine sits standard at the moment with just shy of 160XXX Kms on it.
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7173867
Yep get a Nistune or Link, bigger turbo, injectors, afm if necessary, fmic, fuel pump, exhaust and a good tune. If you want an RB30 later you can transfer the head and all the other bits.
  • Like 1
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7173907
thats the way some as me stock as a rock rb30 limiter bashing hard
https://www.sau.com.au/forums/topic/437616-rb2630-help/#findComment-7175114
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
