Hi from Finland!
First im sorry about amount of pics :D
Here is story of my r34 gtt.
I have had r32 gtst, r33 gtst and now r34 gtt.
After i sold my r33 i was looking s15 or r34.
This is when i got my r34 gtt
First i ripped it a bit
Then started to fit Jdl gtr bodykit
Cutting rear fenders
Then welding it back together
Also tank flap welded :P
New petrol cap
I welded metal between body and fender and after that painted all. Also stripped paint where fender is glued.
Glued with 3m 9115 composite glue
2 layers of fiberglass with epoxy resin
After one layer of carbonfiber filler and two layer body filler
And then some sanding color
Mirrors with diy blinkers
Duck tail phase 1
Phase 2
Final product
Front with gtt bonnet modded to fit gtr bumper. Also blinkers removed and licence plate mounting place removed.
Wheels are bbs lm-r reps, 19x10 offset 20 (+5mm spacer front and 20mm spacer rear)
Headlight polished
Interior got some purple carbon vinyl and fabric
DSC00134.JPG?img=small
Some shots from last summer. The car was made in 4 months. My friend made duck tail and other friend painted final color it but everything else is made by me :D
_MG_0241.jpg?img=small
_MG_0278.jpg?img=small
_MG_0161.jpg?img=small
_MG_0220.jpg?img=small
_MG_7588x.jpg?img=small
And then spec list:
Body:
- Jdl-tuning Gtt -> Gtr kit
- wider rear fenders
- wider front fenders, blinkers removed
- front bumper, blinkers removed, licence plate place smoothed
- rear bumper, skyline text removed, z-tune addons
- side skirt, z-tune addons (removed 20mm between skirt and addon)
- gtt bonnet modified to suit gtr bumper
- trunk lid, removed lock, brake light, oem wing
- diy duck tail spoiler
- gas cap moved under trunk lid
- tail light covers widened
- oem mirrors with diy blinkers
Chassis:
- Cst coilover
- strut bar front and rear
- camber bushed front
- adjustable tension rod
- Linea Corse 19x10 et20 + 235/35-19
Tekniikka:
- RB25det Neo, auto to manual conversion with r33 tranny
- Splitfire coils
- Z32 maf
- greddy oil cooler
- copper radiator
- Greddy fmic
- Nismo injectors
- 3" exhaust
- 2-way lsd
- greddy td05h-18g turbo
Now im working with new front lip
IMG_20140110_181251.jpg?img=img900
And also Greddy turbo is going to change to hx35 12cm + turbosmart 45mm wastegate. Its going to stock manifold :)
New wheels for next summer are Racing Hart Cr 19x10" offset 15
Pic from Japan
1229521136.jpg?img=small
https://www.sau.com.au/forums/topic/438360-r34-gtt-r-from-finland/
Thanks :) I think that duck tail will split opinions, some like some hate :D
I welded screamer pipe and turbo elbow yesterday.
IMG-20140211-WA0001.jpg?img=img900
IMG-20140211-WA0003.jpg?img=img900
My friend welded pipe to compressor cover, Trust ;)
IMG_20140211_171959.jpg?img=img900
Its pretty tight place to fit hx35 to stock mani but after trial fit everything will fit. After install have to start up operation engine bay cleaning :D
IMG_20140204_192151.jpg?img=img900
EZY34, not selling that never :D
Get Some,
Thats custom made. I dont like z-tune lip because it lower car too much so i decided to make my own :) Here are some pics.
20131027_160916.jpg?img=img900
IMG-20131029-WA0006.jpg?img=img900
In this pic i tried my friends carbon wing but didnt like it so decided to stay in duck tail :)
IMG_20140126_145703.jpg?img=img900
Edited by Guula
Very nice. There is nothing better than a super clean look, no body kits.
Thanks :) My goal was keeping it clean. With new front lip i get rid of 2 holes from front :D
Nice build, lots of custom work.
I think I would find it annoying having to pop the boot to put fuel in though lol.
Its really easy to use but i have to replace gas shocks to lid because its falling down sometimes :D
  • 3 weeks later...
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
