Cheers Matt.
Once i have a bit of time i'll be chatting to you more. I was impressed with your knowledge.
My exhaust is sorted and it's freaking amazing (pics to come in the other thread) so this is my next job to look at.... and the damn electronic throttle :P
(oh and that reminds me to add the old 3inch exhaust + dump to my "things to sell" list)
Edited by Beregron
  • Like 1
Just installed my Garrett GTX high flow from by Hypergear. Holds 16psi on HDI cooler kit and 3 inches cat back with no boost controller. Car pulled much harder through out the whole rev range, not laggy at all. Will get at some ID1000 and Emanage, will share my result shortly.
Can i assume this isn't for an M35 Stagea?
If it is i'll always enjoy seeing peoples results.
If not i'm not sure how relevant it will be mate.
Cheers
The chra number in my M35 high flow comes up as an GTX3071. It goes really untuned, I have no complaints.
Don't know if that was covered, I've removed a bleeder jet that was connected from the actuator source to factory induction pipe. That have made a noticeable difference to down low response. The actuator fitted to mine holds 14psi directly sourced, or 17psi with bleeder before it cuts out. Try that and see if it works for you.
Iv just purchaced a 2002 nm35 stagea and by research i may need to invest in a new turbo soon as mine has done 115k which most seem to go by then. I would like abit more power so what sort or mods and turbo should i be looking at for 200kw? Thanks
Dump pipe and exhaust is the first thing to do.
That alone makes a massive difference on these.
Look around for used SS1 spec high flows.
A few blokes here chasing more power and thinking of selling theirs.
SS1 : more torque
SS2 : more power
I have an SS1 with supporting mods that pushes 230kw atw. So if 200 is your goal that will do the job.
I would consider selling my ss1 with an exchange for your stock turbo as I am now chasing a lot more power
  • Like 2
SS1 : more torque
SS2 : more power
There is literally no downside to going SS2 over SS1 (if you're referring to the Precision Turbochargers Sierra Stage 1 & 2). The SS2 has vastly more torque than the SS1, and out muscles it for power as well.
Untuned; my SS2 equipped ran a 13.8 1/4 mile time, Versus a similarly modded SS1 equipped Stagea which ran a 14.3.
There is no comparison, even on the tiny amount more lag.
Hypergear use Garrett ball bearing cores now, their latest RV1 is a GT2971and I've got their RV5 which is a GTX3071. I've driven Stao's Stagea (hdi cooler, pod and exhaust only) with RV1 high flow, that felt like a stock turbo with bit more power, no boost creep.
Mine's cutting out at 152awkws, You will need front mount cooler, injectors, exhaust and piggy back ecu for 200awkws.
Stao's Stagea?
Is that the one that developed a "gearbox problem" and abruptly ended up with a bunch of rods hanging through the side of the block?
Or is that the new one?
I wouldn't say the votes are in on Hypergear's current crop of NM35 Highflows; hopefully he can get on top of it.
152kw is basically what a stock car produces! Picking the right turbo for these cars is the make or break decision that gives you either; an absolutely fantastic car, or a steaming pile of shit.
Before my car was tuned; it produced 179kw @19psi with an Precision Turbochargers SS2 highflow, HDi Intercooler, 2.5" suction pipe, 3" dump to tip exhaust with a 100 cell cat, and Walbro pump.
It then went on to produce 226kw @ 13psi after fitting and HDi Max-rom subcomputer. This was with stock injectors, and reg.
Recently Lakes101 ran 245 kw @17psi (I think) with essentially the same supporting mods as mine (including Max-rom); but notably with main difference being the awesome Intense Billet RS highflow.
245awkw on STOCK INJECTORS.
  • Like 3
152kw!! On a gtx3071! I ran 176kw an the stock turbo with Walbro pump HDI intercooler and 3" exhaust. You should be pulling at least that with that turbo. Not familiar with tao's (stao's) turbos as I've never had one but honestly haven't heard good things about them.
Once I upgrades to the intense billet RS turbo and 2.5 intake I pulled 245kw on stock injectors.
  • Like 1
152kw on stock ecu and injectors. boost cut at 14psi lol. I've looked at the intense Rs, problem is they can't run anything less then 30psi, Car is my daily, no local E85 pumps.
Hypergear's got a totally different rep in other crowds. They are working another M35.
Those results kinda speak for themselves.I assume this was running E85 and decent boost?
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
