hi everyone i am having a problem atm with my r33 gtst rb25det it has been a problem since i have owned the car even after i have swapped motors.
when warm or cold as coming onto wot the car surges from 2000rpm to about 5000rpm then after that it completely frees up.
its a bad surge and if i hold wot when it surges it back fires and sounds like there's a front fire ?
standard boost well standard setup,
has front mount.
i have got new plugs gapped at .8
and have swapped coil packs no difference at all
timing is at 15 degres and the more timing i give better it gets
also has a new walbro hp fuel pump cant remember what models was good for 300 hp tho.
but when car is running or fuel pump is primed the fuel line isnt hard hard i can push it half way in .
any ideas on what it is guys all help much appreciated ??? thanks for reading :)
https://www.sau.com.au/forums/topic/443331-r33-gtst-rb25det-surging-help/
Checking the hardness of the fuel line won't tell you anything, that's what a fuel pressure gauge is for.
Obvious things to do are clean afm and check for boost leaks.
Aren't you the guy with the rb20 turbo that glows red all the time, drives hard everywhere and just got car out of impound?
If you are at all concerned about low fuel pressure......then why not either install a fuel pressure gauge into the line or take it to a mechanic who can so you can see if there's a problem or not?
yes that is me. i have started to drive normal now thanks to the new hoon laws i just want car to run good thats all
y
Are you sure you checked the timing right? Did it with a plug lead between cyl 1 spark plug and coilpack and then put a timing light on
Sounds like timing to me, especially if it gets better as you advance it
Is the CAS dead?
Of course I would agree it could possibly be the afm as I already suggested that.
and also i took the rod off the actuator and its runs smooth as f**k obviously no boost ? so what do u suggest there? i have put a afm and borrowed a cas still the same ?
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
