2015 Nismo R35 Gtr.
There is talk in the R35 community that Kelly Racing is trying to do a deal with Nissan Australia and Nismo to bring in a handful of these to Australia for road use. Would be interesting to see the asking price
  • Like 1
would not be an attractive price - how much better is it really anyways than what you already have?
At the price quoted above, it works out to be around $163,214.87 AUS.
Power is up to 443.69 kW's (595 HP) and 481 lb-ft, up from 406.41 kW's (545 HP) and 463 lb-ft due to higher flow and larger turbos from the GT-R GT3 race car.
Bilstein DampTronic shocks with new Track, Race, and Race Plus modes with stiffer springs.
New front links increase caster trail and both straight-line and cornering stability.
Dunlop 255/40-20 front and 285/35-20 rear tires.
Larger bolts in the wheel-hub attachment area to stiffen the assembly.
Out back is a hollow, 17.3-mm anti-roll bar, and the entire structure of the NISMO version is stiffened by a claimed eight percent using more adhesive bonding to complement additional seam welds.
Updated interior / exterior.
Redesigned spoiler for to increase down force yet still remain the same coefficient of drag.
http://www.caranddriver.com/reviews/2015-nissan-gt-r-gt-r-nismo-first-drive-review
Trust me it won't be sold here for $163k it will be more $200k mark (if not more)
  • 5 weeks later...
  • 2 months later...
  • 5 months later...
Nismo has already set up operations in Australia. There is already a Nismo place in VIC.
however from what we have heard so far, is that the Nismo GTR will not be on the list of cars for sale - only the Nismo 370Z and the Nismo Juke R for now..... will need to wait and see.
 Share
    • This morning I carefully reinstalled the manifold and started looking at a couple of things I need to do.  Heat wrap arrived sometime today so I popped into the shed with the missus dishwashing gloves and started wrapping the first half of the dump and the screamer/plumb back.  Once I do the second half I'll be able to final fit the turbo and exhaust up.  Also pulled the harness out today and started terminating it at the ECU end. A connector is done, just need to run the remaining wires that arent in the harness - 12v, gnd and couple I/O
    • A31 is pretty much the same thing without HiAIDS I mean CAS, no improvement lol. Not to late to send it.
    • Thanks for all the replies! I also wanted to ask if wheels that were fitted on Ford Falcons would fit the 350GTs as well? In the area I'm at there aren't that many options for secondhand wheels and new ones here are way out of my budget. From what I've seen, most of the wheels that are available that were fitted on Ford Falcons have an offset of +33 to +36, with a centre bore of 70.5mm whereas the stock 350GT's ones are 66mm, can't seem to find any hubcentric rings that fit that difference though.
    • 215/45/18 tyres are probably a little on the low side compared to the factory tyre, it should be closer to a 245/45/19, which will get you about an extra 11mm of height, and should make you speedo read a bit closer to reality. 245/45/19s will be a bit too far the other way and you risk a speeding ticket as your speedo might read slower than your actual speed.  245/40/19s would be correct if you are going to 19in rims, they will give you a similar total diameter to the 245/45/18 tyres.
    • That's something I forgot to put in my list. The aggressive anti-squat in R32 is a f**king menace. I still need to decide if I'm going to drag the subframe out of my car and weld in the GKTech corrector kit. The main reason to dither is the need to switch to spherical joints in the lower arm to account for the twist induced in the rear pivot caused by lowering the front pivot. And yes...we do put better subframes in R32s, and I wish I'd gotten an S14 one instead of an A31 when I did the "take off and nuke it from orbit" HICAS delete all those years ago.
