  • 1 month later...
So, had another trackday at SMSP. This time the north circuit. Had a great time with a group of mates.
Car overall was pretty good, and drove home from the day. I still think the car had more in it than I could get out. I really was stuffing up turn 2-3. So. I think there was a second to find going another 20m deeper into t1 (which is scary as fk getting down to the 100m marker), and putting t2-3 and the last complex together.
Couple of things to work on, car had a bit of a misfire when it gets hot. I think the intake temp is getting up late in the sessions. Second thing I need to start looking at coilovers as I think the teins have seen their day.
Couple of vids to come ;)
One of the sessions battling with the usual SAU suspects
I ended up 8th of 64 cars!
Ending up inspecting some tyre barriers nice and close. Really didn't enjoy hitting that kerb.
Cool stuff, looking at bit wide-eyed at the 0:38 mark in the 2nd vid :) What happened there, lost traction when jumping the kerb? It happens mad quickly when it happens eh
Yup, I went in too deep for a start so the car was unsettled, and even though I had hit that kerb with no issues before, this time it threw it quite sideways. By the time I straightened it, it was heading off to do some agricultural work.
  • Like 1
  • 3 months later...
So the car has gone back to live with its previous owner. Many happy memories in this car.
But, the next project is inbound, and it is a very serious step up in Motorsport. It's going to be eye opening.
  • Like 1
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
