On different setups, I ran the GTX2860's with the stock anti surge front housings with welded on flanges in my 2.8. In short they come on boost later than a 2860-5. They are quieter though
he modified the gtx housings to fit the Gtr
Yes married Thursday
I'M back again with more news... mechanic told me my oil seal is leaking and if i dont change it, turbos will need rebuild. Since I'm not doing any mechanic on my car, i thought.. if im going to pay labour $ to have my seal/gasket redone, I might as well check my turbo and swap them with brand new turbos to recover optimal performance of the car.
I found out about a company called Pure turbos..
They ask 1100$ to have both turbos rebuilt with new brass cage and new billet wheel. ( they say it will be as good as brand new turbos , if not better due to brass cage and billet wheel)
Now heres where i need your help... they offer me a 60mm billet wheel which should yeild a 40hp/per turbo upgrade ( probably taken from the gtx2860's figure) and a 63mm which would yeild 80hp/per turbo. They say turbo spool shouldn't be noticeable and if it was their engine, they would go 63mm.
I'm scared the 63mm will actually be too laggy and i have doubt about their claims on spool. if I had 2.8 stroker.. it would be a different story, but I'm only on a rb26 with 86.5mm.
What front compressor housing are you using, normal -5 or surge slotted? You will be more at risk of compressor surge with a bigger compressor wheel.
-5s housing !
Considering you only wanted 500-550 Whp, it's a not brainer. 60 MM wheel!
I also feel the same.. but you know.. if the lag is going to be 200ish rpm and your gaining an extra 40hp/turbo.. it's interesting lol.
200 rpm is heaps!!!!
Very true, people don't seem to understand what a few hundred rpm can do to a car...
My T88 on dyno was only 500rpm (ish) slower to get 15psi on the dyno compared to the 6262, on the road/track it went from being horribly laggy to very responsive
  • Like 1
^^ *like*.
Micko's old man changed his exhaust and went back to a stock airbox on his GTR. Overlay the graphs and it was 200 rpm everywhere. TOTALLY different car to drive. It went from a car which did nothing under 5000 rpm to be able to drive it quickly quite easily.
60mm. Do it. Don't forget you have a 2.6 too. A bigger engine you'd get away with it.
  • Like 1
Some open pods. Mmmm all that yummy hot air!
It was a 33 though. Different design to a 32 box.
I know I'd make more power going back to an air box but I'd never thought about earlier spool as I wouldn't have thought it would have made a difference.
I'm pretty sure I'd still be fine with a standard box at 325kw.
The whole shebang coming on earlier was more to do with sorting the pos "jap" exhaust out. Getting rid of the rubbish restrictive mufflers and mismatched pipes. Going back to the airbox was just something he did at the same time.
  • Like 2
Yep picked up 15-20kw throughout the midrange to redline. Was a night and day difference really was much nicer to drive and also made power feel more progressive not just a BANG & it was alive at 5000rpm :)
There are times I've seen NO difference in spool on the dyno and still a very noticeable difference in practical use - dynos can be quite misleading at times!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
