fairfield rd fairfield 5 pm purple 33 i was in r32 hello
Heya!
Cracked the gate because couldn't high beam lol
Also spotted GO44IT? R33 S2 super clean and shiny coming down my street!
Saw a few at WSID. Nice 34 GTR and MNP 33 GTR, a white 33 gtst ran a 12. A 34 with an unpainted bodykit and a few other 32's. One poor blokes rear window shattered down the track in a 32.
how the hell did that happen?
I saw your car too, very nice!
About 9.45pm tonight and again around 10.30pm, a black (matte black?) R33 GTS auto with a pretty loud exhaust cruising through past the sports fields and mini skate park in Baulkham Hills, just off Seven Hills Rd.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
