I have done it from start to finish.
Don't. Don't. Don't. Don't. Don't, Don't.
Just sell and buy a turbo car. Seems like a hassle? Its far, far less hassle than going the alternate direction.
  • Like 1
Whether or not you are attached to the car, that isn't what the thread is about. You asked how hard and if anyone has done it. Someone has, and said don't. You don't want to stuff around with turboing an N/A. If you like the car, remove all the parts you like about it, and replace them on a turbo one.
What you mean by legally registered...i know it's easier to sell and buy knew one but I just can't let go of this car ...
Let it go, the car is most likely what you want it to be - perspective is required.
You just don't know it yet as you haven't gone turbo.
Lets be completely clear here, in the nicest possible way - Anything you've done to your N/A can be done to the Turbo car.
All the hassle of doing this, moving bits over is FAR LESS than trying to turbo your N/A.
Especially if you want to do it legally (which is an engine swap, ecu swap, brakes swap, in other words... you're replacing all the car bits except the chassis)
SO what do you want to do
Replace some wheels, or interior bits.. or replace the entire guts of the car to make it... uh... a turbo car.
Its far easier to replace the car, and believe me when you do it, you keep finding little "non turbo bits" that aren't the same as the turbo bits. These appear often, dumb things like plugs, different wiring which may not be turbo spec, random bits you buy online you find don't REALLY fit when you are told they should.
It's a pain, a stupid constant pain you live with.
People saying "sell it and buy a turbo" aren't being dismissive - They've heard it time and time again. Same with people who end up putting rb26's in GTS4's etc, it's always "just save and buy the GTR"
It's all about saving on headaches in the future which will occur. Far bigger headaches and heartaches then selling and buying a car that's already made.
  • Like 1
It's really not that hard/expencive if your just going to put stock hot n cold side, using the standard oil, water feeds (they're just blanked out) then add some sort of Ecu couple other little thingg I did this on a 33 year's ago. The issue then is suspension and breaking are below standard and you'll be limited to low (5-7psi) boost to protect the motor. It's a great little upgrade if that's as far as you go but if you get the bug and you probably will you'll want to do more and then you may as well throw all that money in the bin sell it and get a turbo.
By which time you won't be able to sell it at anything near what an N/A skyline sells for because it's unable to get a roadworthy certificate or be legal on the roads.
If you're on your P's... wait till you're off your P's...
If you're off your P's... sell it and buy a turbo and you can MAKE money AND have a much faster car with all the other stuff that turbos have (proper brakes, suspension etc)...
Alright thanks guys but how won't the car b able to get road worthy ??? My current car has coilovers already ... So brakes won't b to much of an issue to change .... I really won't b able to let this car go ... And money isn't a problem ... From what I heard it's easy to turbo a 25gt but how bad can the problems get and still don't understand how I can't get it registered ...
Thanks guys big help :)
If money is no issue buy a better car.
If you don't understand the registration and even insurance issues then the conversion is not for you.
That lost by Kinkstaah was perfect and summed it all up.
So you can't let car go because it had coilovers? Or something more special? First root was in it?
I really don't get why people get so attached to some cars. why not get attached to your first good car?
Ring up the registration department and ask them what the deal is with a turbo conversion.
Well for one the body has had a shit load of work done to it .. And I don't want to be wondering around buying new cars I actually want to keep the car and work on it do things myself to it... If it's really that hard and bad ill just leave it n/a... That y I asking these questions ....
That's the thing, and being polite as possible....
.....anything you have done up to now is easier than going (legally) turbo.
going (legally) turbo requires a full engine swap in Victoria.
this means you also need to fit GTT brakes (I got away with R33 GTST brakes, as they fit the NA R34 (gtt is different)
this means you're also likely to need a different gearbox (ultimately)
this means you're also likely to need a different diff (dat N/A open diff)
this means you'll need a different ECU
this means you may or may not need different looms because new things exist/old things don't.
My problems all started because I got sold a NA+T which I had mistakenly thought was a GTT (new to skylines at the time).
"I'll just modify it to get what I had paid for" as chasing up the seller wasn't feasible at the time/was considerably later on/seller was dead.
This isn't a path you want to go down.
Sell the car/drive a factory GTT and you'll be like, um, yeah, this takes exactly zero labor for a wildly better, factory result that needs exactly no involvement.
But hey if you want, I'm trying to sell my wreck. feel free to buy all my parts, but you'll immediately decide its wildly expensive, even if you DIY. "There's got to be an easier way" you'll think, which is simply to buy the GTT and retrofit or enjoy its different body kit or what have you.
Well thanks mate at least u explained it to me in more detail I know it's a hard thing to get through my head main thing I am concerned about it the engine swap ... I still got 2 years of p plates so give me a good time to think ... ... Thanks mate
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
