Thanks for this info, I'll pass it on to a mate of mine who is having/has had work done there just to make sure he checks everything himself.
That's utterly appalling and is grounds for legal action, in terms of negligence.
Sux is one way to describe it.
On closer inspection we believe it's been ground by hand, not as a result of scrubbing.
There's only the lightest witness mark on the rotor, certainly not the damage you'd expect if it was in contact enough to destroy the arm.
The problem is the clearance to the rotor, obviously when the rotors where installed on my car, instead of correctly spacing them, the person (who shall remain nameless) chose to butcher my arms instead of doing things properly. To hell with my expensive arms or my safety!!
In the words of the workshop who currently has my car:
The issue is the incorrect brake rotor offset. The existing front brake set up is an absolute mess.[/size]
· No rotor location to hub, other than on the thread of the studs
· Rim location to hub is only 1 mm
· Calliper not central to rotor
· Calliper body fouling on dog bone
· Calliper mounts in uprights have been drilled (opened up to allow radial alignment of the calliper to the rotor )
· Dog bone to upright threads stripped – calliper was loose.
· Etc etc
WTF!!!, that's is truely farked up, luckily that didn't end badly for you whilst lapping this thing
And the reason I do all my own work, then I know what's going on and feel safer tracking them
  • Like 1
· Etc etc
thats just truly messed up.
Someone trying to kill you buddy?
It's been like it for atleast 12months. Lucky for me my car hasn't done many laps during this time......given I've only made it to lunch twice in the last 12months.
We've been so busy chasing "other" issues it's been missed.
Certainly now on the must fix list!!
Wow, lucky it wasnt worse i guess... Shonky basterds...
Hopefully its all sorted and good to go soon?
It will be resolved properly after WTAC. For the moment we'll just try and add some strengthening and do minimum laps Fri/Sat.
Pretty much all you do at WTAC anyway... Pick a session with reasonable weather and go do 1 hot lap, then park it like a pro.. ;)
Haha fair enough... Will see you there ;)
I hate dodgy workmanship with a passion. People like that need to be taken out back and beat with a hose.
On a positive note, all the best to those competing in this year's WTAC. Eager to see how Richo goes in clubsprint.
Cheers
Amir
So apparently it is going to rain Friday and probably Saturday.
Will be interesting to see who has done some wet weather testing and how quickly the teams respond
Did you see the rooster tail from the S15 in testing :woot:
Is there much cover at the track for spectators? I've never been.
Bring an umbrella?
Yes and no... Brolly is a good investment me thinks...
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
