hi there,
im sure this has been asked before so sorry for the repeat, have been trying to search and seems the search bar (or my pc) hasnt been working for a few days.
anyway, my brother drives a 2003 (i think) 350GT he has recently upgraded to much bigger AP racing calipers and rotors
so here i am thinking i need bigger brakes when i see them in a box in the shed and they would be about perfect for what i need. (2 pot rear 4 pot front i think)
would the rotors and or calipers directly bold on? and if not what would be involved in making them fit?
also would i be needing a bigger than standard master cylinder?
cheers
Caleb
can anybody confirm? i have heard somewhere that fronts may fit but backs will need mounts drilled out and spacers put in, (possibly front too)
would be bloody awesome if i could use them
they aren't the same as 34 gtr brembos but im guessing u know that n ur suggesting that as a replacement booster. cheers tim!
My apologies, I got confused reading your user name and linked a R34 instead of R33 ABS MC. Revised link.
http://www.kudosmotorsports.com/catalog/genuine-nissan-pitwork-brake-master-cylinder-bm57-1716-nissan-skyline-r33-gtr-p-1044.html
Nissan Brembos calipers, including R32 (N1), R33, R34, 350Z, and 350GT are all the same. Only the disc size varied slightly between some models.
Brembo calipers use M12 x 1.5 bolts up front. Sumitimo calipers use M12 x 1.25. Therefore, if you have the mounting hardware, they're a direct fit.
I fitted r34 gtt brakes to my stagea (rs ) which has 12mm holes in the struts.
I machined up new inserts for the calipers with M12 threads.knocked out old ones knocked in new ones. Heaps easy.
Maybe I should make a heap more....
thanks heaps for your replies everyone
think i might just do with good pads and rotors with standard m-spec calipers until im tracking it and upgrade then.
took her up springbrook mountain last weekend and didnt fade too much even with cheap pads and rotors
yeah tim, my cousin used to drive a 34 and made an account under my email for some reason now i cant make my own account hah.
Interested to hear how you go with this upgrade ? Only because i used to have a 350gt with the brembos and they underwhelmed me... this was with proper bleed/dot 4 fluid and TRW lucas pads and good tires.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
