  • 11 months later...
Ok
I'm about to re configure my fuel system with a walbro gss342 255lph pump intank to a 4 to 6L surge tank fitted with a walbro 460 e85 pump.
Will only every run pump 98 as car doesn't get used often.
From what i have worked out from the walbro gss342 255lph pump graph at free flow it should be pumping around 75 to 80gph. For a lift pump only set-up.
Is this correct.
I'm sure the 460 e85 pump will support 22 to 24psi of boost on a gtx3582r on a 2530 neo engine on p98 Just have to make sure lift pump can keep up thats all.
Edited by lcxu105
Autocorrect
The flow graph says you have lots more flow capability with that pump being fed 13.5v.
Going off your sums, those flow numbers say you hit an equilibrium point roughly at targeted max injector flow.  Is there any chance you'll be staying at that point for more than a few seconds at a time?
Run the GSS342 at 13.5v, peace of mind.
No it wont be held at max duty cycle for long as you have said . Pump will have 14.4 volts so will be way more than enough at free flow capacity for lift pump work. Having said that if i ever do decide to get flex fuel tune and larger injectors it will be line ball game i think. But should be ok as i will fit sure tank with a low fuel sender so i know to lift my foot just incase.
Edited by lcxu105
Autocorrect
Anyone seen or used the new (ish) AEM 380lph inline fuel pump ?
looks to be a direct replacement of the Bosch 044 but flows more everywhere !
http://aemelectronics.com/?q=articles/aem-releases-380lph-high-flow-high-pressure-fuel-pump
  • Like 1
I haven't used one, but I have one BNIB if you are interested! They are a direct replacement for 044 (why I bought it in the first place, but changed directions).
Not e85 compatible. Well maybe, but not for long haha
Run two of them with E85 and 5 Bar differential fuel pressure with 1800cc injectors (@ 5 Bar) at 90 % duty and they hold 5 Bar differential pressure perfect.
Only dyno work so far so cant comment on longevity but for the price not really a concern.
  • Like 1
Would you say they are better then the 044 in terms of flow ?
sometimes I don't know weather I should believe all the flow charts manufacturers through out there so would rather hard evidence like urself
thanks
Be careful not to buy fake pumps. These days it's getting harder to spot a fake one from a real one. Heres some picks of a fake gss342 255lph walbro pump i was sent recently after the seller reassured myself it was genuine before purchasing it and their add guaranteed it was 100%real. Long story short i was lucky enough to get my money back.  Fake pump is in my left hand in photos.
  • 3 months later...
G'day fellas, a few questions about fuel pumps.
I am currently running about 275rwkw @ PULP with Hypergear ATR43SS2 at 20psi. I am thinking of retuning for E85, aiming for somewhere around 300rwkw. Here's the current fueling setup, it's pretty basic:
  • Walbro 255LPH fuel pump
  • Deatschwerks 800cc injectors
  • Fuel pump rewire
The injectors have been used with E85 previously and I am confident they have enough flow for the task.
Questions:
  1. What's the chances the Walbro 255 would flow enough for E85 at ~300rwkw?
  2. I don't think the Walbro is specifically listed as 'E85 safe' – has anyone run their Walbro 255 with E85 reliably?
  3. If I need to upgrade the fuel pump, what are the in-tank recommendations for this application? The Walbro 460 seems really popular but is it an overkill? Are there any downsides to running an 'oversized' fuel pump?
  4. Ebay is full of pump labelled 'genuine', but how can you really know that it's authentic?
Thanks guys.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
