4 hours ago, Dose Pipe Sutututu said:
I highly doubt the A1RM are rated up to 780 deg. C.. if so why the heck do they crumble like a cookie on the track and the likes of Intima SR and Project MU HC+ / HC800 pull up fine - and both are rated much lower.
The 780C came from this QFM page: http://qfm.com.au/page/6/Performance_Range
3 hours ago, admS15 said:
I just finished off my first set of a1rm at Winton yesterday. Copped solid abuse for six sessions from start to finish, no cool down laps, last session was 10 laps and best lap of the day was on that lap. Pads where 50% at start of the day, didn't crumble but wore them right down. The rears where qfm hpx and they didn't like that treatment, they ended on just about metal on metal. In saying all that, at more demanding tracks like sandown, I don't think they will go too well. They are ok for the not so serious track car but it's the old saying, you get what you pay for and since I got another set for $60 for the front, I have put another set on the front. I measured the disc and compared to the measurement I took when they originally went on and the wear was 0.6mm. I thought that was ok. 4 track days, 1 set of pads, 1 set of tyres and 0.6mm of disc. Budget racing brahemoji3.png
Thanks, good to know!
I need something that can take the Sandown 200->90km/h punishment down the front straight repeatedly, and I'm tossing between Intima SR or Forza FP3 as a step up from Remsa.
I got some R33 GT-R OEM brake ducts off a forum member (thanks!).
I went to measure them tonight and they're pretty hefty, the height is 50mm. I'm already height challenged in the front so mounting these beneath the undertray/liner is most likely not an option..
Does anyone run similar brake ducts in their R34 (GTT or GTR)? Is there any chance to squeeze these above the liner somehow?
Otherwise I might have to set up vents and soft ducting from the fog light openings. It's a series 1 front bar.
  • Like 2
  • 4 weeks later...
I just finished fabricating some front brake air guides over the weekend, made out of 0.9mm galvanised steel. The design is largely inspired by the UAS ones (thanks dan.1337 for the photo and link!) but also looking at the OEM GT-R V-Spec ones. The most time consuming part was testing a number of prototypes at varying levels of lock and suspension compression to ensure that everything clears at all times.
What do you guys reckon, should I make some for the rears too? I cooked my 650C pads in all corners last track day (granted not enough cool down laps). I have since had the rear heat shields removed too, which hopefully cools rotors more evenly but will probably heat up drive shafts/boots/suspension components more now...
Also the R33 front brake ducts won't clear at my ride height so I'm thinking of adding just some rubber 'fins' on the undertray to channel more air towards the air guides. Might be an overkill.
Here's some photos of the front brake air guides (car jacked up, suspension fully expanded), yet to be painted:
Front left with steering straight
Front left with full lock in
Front left with full lock out
Rear right with no heat shield
The prospective air guide would follow the curve of the lower control arm edge I imagine and feed into the small gap between inner edge of the rotor and the handbrake assembly?
  • Like 3
8 minutes ago, admS15 said:
Thanks man! A lot of the ones you see around tend to cool the disc face, I like the UAS style as it feeds inside the disc to allow the vanes to vent more effectively.
Also quick tip for anyone wanting to give this a go: the jigsaw with a metal cutting blade was a revelation after initial struggles with tin snips...
that's really cool!
did you just use those U bracket things (those brackets to hold up conduit) to attach it?
Lol :)
Yes three mounting points: 8mm bolt at the hot end, widened 25mm conduit bracket in the middle, wide cable tie in front. I'll try to get a photo from the back later.
Here's how the front right looks from the inside, you can see the three mounting points:
6 hours ago, mr skidz said:
We need to make a mould and carbon fibre those things they'll sell like hotcakes
Or maybe someone can scan them and produce them on a 3D printer.
Could work but probably over-engineered :) It's just a flat sheet cut up to right dimensions and bent. I might look at doing a template if these work at Sandown next week ;)
Both front and rear air guides went well at Sandown today, with no ill effects. No brake fade but I didn't get any good runs in either as I had to nurse the car, pretty sure the head gasket is gone :/
Here's the rear left mounted:
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
