A whole block of them from SAU will look superb > draw a crowd > probably elicit discussions over mods with bonnets up too...
They won't be just 'pretty'.
Maybe a few enquirers will take away Membership Application Forms like 2013.
  • Like 1
I'm tempted to enter the LOLvo, but it still has that big ugly scratch in the bonnet and I can't be bothered having it repainted and/or covered. Otherwise the car is reasonably presentable - far from perfect, but not horrible either.
  • Like 1
Hmm, their Facebook page states the following for approval dates:
FIRST ROUND APPROVALS: Monday 15th September
SECOND ROUND APPROVALS: Tuesday 30th September
FINAL ROUND APPROVALS: Monday 13th October
So you might hear something today; or otherwise you'll have to wait until the 13th to get final word.
The Nur will get in, the rest of us wont because we're not part of the stance crowd or showroom condition.
Remember its not what you have its who you know, least thats the impression ive been getting over the past 12 months
Can we throw up some pics of the cars that have been accepted / approved then? Also helps so that we can recognise the cars as SAU on the day :)
Eric (Pezhead)'s R33 GT-R:
Dave (Aggroman)'s R34 GT-t:
    • I mean, I can confirm the TPS is at 100%.... I can confirm when we installed the TB and setup the cable that the TB was indeed fully open at max pedal travel.. the same 'curve' (WRT MAP vs MAP) existed with the previous setup/TB/manifold as well... No, we did not do a run with no intake connected. I would love to go back in time to do such a run to rule out the intake. It would have also been good to do a run with the airbox lid off. There's a test there where increased IAT vs more available air could be a positive tradeoff. I remember taking the lid off my R34 Turbo setup back in the day and noticing a monster increase, even if IAT's did go up. Could be similar. Hard to test unless I find a very deserted road.
    • That's actually encouraging to be honest. my motor was rebuild many years ago but it's probably done less than 30,000kms and fucc all limiter or drift, majority street / drag / roll racing. It'll be fine 💪🏼 I don't even have lines or a can for the cam breathers installed yet, there is zero oil residue or splatter on or around them, it drives beautifully so it seems healthy. Just a ticky lifter, yet they're almost brand new oem genuine Nissan and haven't done many kms at all...
    • Have you confirmed the throttle body goes to WOT (and stays there) during the run?
    • I'm having a problem. I think it was mentioned above somewhere but can't see it.  I'm stuck in the cycle of, sand, filler, low spot again, put filler, sand, low spot again, now i put filler again and a thicker portion which seems to have helped but I got low spots in other areas. In the image. Circled in red thats where the original low spot was and the shape is the same as the red out line. I've more or less fixed that (still low spot up the top but now I have low spots where the green circled part is.  Is likely the issue that I didn't start with a course sand paper? I sanded the filler with 240 to reduce the risk of not going to far but maybe the issue is that I'm only taking off enough material to remove some of the filler but not the high spots. I now started sanding with 120 and I think I'm seeing a difference. I did fix one dent the other 2 are f**ked and seems like I made another low spot which is indicated by the furthest green circle on the left handside. Any thoughts and solutions?   Also second image. All of these rock chips, can they be filled in with primer or do i need to fill them all with filler/putty? So many rock chips on mine lol.
    • Well, I had an Edward Lee's special edition odo windback car/motor with a RB25DET S2 and I put down 372kW with a good amount of track abuse for 1.5 years before the ring lands decided it didn't want to stick around anymore 🥲 But probably didn't help I kept on smashing try limiter on the track and a few skid pans.
