Where's the love for the Chaser, Ciaron??? :laugh:
Great day!! I had such a good time!! Aimed to beat Brian's time, but... you know... didn't quite get there :laugh: :laugh: :laugh:
Thanks heaps to Mum Wootten for being an awesome baby whisperer, and to Nick and Dave and the other Execs and volunteers.
Haha she loved it!
Thanks for taking me on a hot lap too ;)
i had a great day on Monday first time for me on the track and have heaps to learn, was a nice group of people to be with thanks to all who made it happen and thanks to Dave for lending me his oil cap and helping me with some catch can issues
My favourite line from the day shell was with Tats.
Dave can you get me a form out of that folder on the I cant bend over that far.
Hah you lazy F**K!
No I have a baby strapped to me
*looks in his direction* Oh well don't I feel like an arse now.
Here is my in car from the Corvette.
Few laps with Steve Ka as a passenger frying some rear tyres
https://www.youtube.com/watch?v=jyNCGMZzLPM&feature=youtu.be
2nd session lap two is the 60.7sec lap which took fasted time off the day.
https://www.youtube.com/watch?v=Iv6I-kG3Ghs
Does it even go in a straight line? ;)
  • Like 1
Was a pleasure.. even if I did get a little bit dizzy. ;)
Running Kumho V70A Semi's.
Here's my 1st run of the day..(HD available)
Nice laps. What's the read light on the tach? Is that an oil light coming on?
ah, nice. Was just odd cause I noticed other times the revs were up but it didn't light up.
Yeah, if the revs are rising quick, then the rev lights come on sooner to give you more warning, But if the revs are rising slower then they don't light until you're closer to red line.
I tend to hold the throttle a bit when I change gears, hence the revs momentarily rise quickly between gear changes and thus the light gets lit. :)
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
