  • Replies 50
I don't see the small block chevy as such a bad thing.
They still use it in the Corvette so what's the big deal?
Should be a nice ride but I'd be thinking alloy head or even block.
T.
Do you recall the HPI article that had a Corvette chop an R33 GTR in a straight line, and also the HSV GTS with exhaust, cam and remap that went even stevens when both jumped on the loud pedal with an R34 GTR running exhaust / filter/ Power Fc and boost...
Chevs are alright in my book, the problem is finding a decent chasis to put one in :(
I think there is a few people in here with a fear of torque....
Not really.. I tend to think that the RB2x is an integral part of what makes a Skyline a Skyline, in the same way that an RX7 would not be the same without its rotary engine. The engine is (an important) factor in defining the cars character.
Hence sticking a thumping V8 fills me with mixed emotions. Good for him for doing something different, but IMHO its the same as dropping a V8 into anything and not really a "skyline" anymore.
LW.
Also, it's not like our RBs are torqueless - so everyone thinking "just imagine the torque" might want to rethink that. Turbos are one of the best ways you can add torque. Just look at the latest WRX STi - 394Nm from a 2L!
That aside, I do like the idea of a V8 in a Skyline though. It's something different. That engine would just be near the bottom of my list. VH/VK series or a 3UZ would be the way I'd go. Good work though, anyway.
I think I remember reading that.. Basically the only thing giving the gtr the upper hand was the 4wd.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
